Question about Refrigerators
Won't cool down
I just brought a new Dometic RM 3962 for my houseboat. I hook it up on the boat this pass weekend to 120v and 12v and it won't cool down. All it said was 60 degrees.
JL Beach
  • 828 Answers
The gases in the system may have totally separated. Try (burping it ) as follows. Witht the refrigerator sitting on its base, roll it on to the door and wait 5 minutes, Then roll it to its top so it is literally upside down, wait 5 minutes. Then roll it to its back and wait 5 minutes. Then restore it to its base and wait 5 minutes. Thi procedure will flush the water from the boiler section through the passages of the system and recombine the gases. Then try it on 120 Volts. It takes about 12 hours for the unit to fully cool down.
Posted on Jul 07, 2008
I have a Dometic RM 2620 fridge, that won't cool. A squirrel got into wiring, I have taken care of wiring but will not work on gas or AC. Spark igniter will no spark either. Any ideas?
Since I don't know what does work I am kind of shooting in the dark.
Does the ac heater get hot ?
The spark ignitor is part of the control board. But won't work?
I assume that you have a user manual but I am including a link to download one.
https://www.dometic.com/f6e8a773-69f5-4624-9b35-54e8801da7af.fodoc
Note that there are three fuses. B (12V control) and C (120V Heater) on the control board and a thermofuse L located on the stack.
If L is good and everything else is good there should be 12VDC on J1 and at Fuse B
Sep 19, 2014 | Dometic RM2620 Refrigerator
Dominic 2820 won't get cold
The Dometic RM 2820 was working last night. This morning it was not cooling and now the front panel and interior light are not working. No smell of ammonia. Any help with this challenge? Thanks,
Jun 11, 2013 | Dometic Classic Rm2820 2 way
2 year old RM 2620 fridge, stopped working. I have power to the plug where it plugs in, but there's no lights or cooling now. Fuses are fine.
On the back side of the unit there will be a small thermostat switch mounted on the heat column. It will be round with two wires attached to it. In the center is a reset button. If this button does not restore power then the next step is to replace the wire coming from 12v supply to the thremostat switch. The wire will be red and will have a black sleeve on it. Under the sleeve is a safety diode (to prevent overheating and fire), it will be held in place with three bendable metal fingers. If the diode is bad it will not allow 12v power to pass through to the circuit board. Even though the refrigerator is running on 110v power the circuit board still requires 12v power to operate. The diode is a part of a FREE recall kit offered by Dometic so your local RV repair center should be able to help you out.
Oct 17, 2011 | Dometic RM2620 Refrigerator
We have a 1993 Wilderness RV with a Dometic refrigerator, brain box being of Dinosaur brand (which is ok - reaching 120 volts) Our question is on the front freezer door of the fridge is a strip plate...
Hi
Most of these mobile refrigerators can run on gas, 120v or 12v, your gas option is obviously OK, there should be electrical connections on the back of the unit which identify which cable are 12v and 120v.
Again most but not all units were multi option.
You will need to connect these points to the supply. To run this on mains 120v you will need to switch off the gas and 12v, similarly for 12v, no gas or 120v, and for gas no12v or 120v.
If you get the fridge to run on 12v remember that if it is on overnight it can reduce the battery charge.
The best options for these is gas or 120v when you have a mains hook up
Hope this helps
Gordon
Apr 18, 2011 | Dometic Refrigerators
Dometic rm 3962 interior light stop working, blub is good, switch is good, no voltage going to the light
replace the bulb holder or receptacle may be the terminal of the bulb cannot continue the flow of the current it has a burn contact or loose contact.or try to dismantle the wiring box maybe ther is a loose connection
Feb 14, 2011 | Dometic Refrigerators
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
Unit cools fine on 120V, selecting GAS CHECK light on.
Do you hear a clicking sound If not. there is a black box inside the out side door. Check the fuses in it.
Ken
Sep 23, 2009 | Refrigerators
Refrigerators Logo
170 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
