Question about RCA 32V524T TV
TV trys to come on but colors streak down screen for few seconds then it shuts off (2006 tv)
I decided not to sign up at this time for premium assistance because I know that it is either related to flyback transformer or regulator. Because I do not have required test equipment to perceive which, I opted to take it to the shop.
Posted on Jul 08, 2008
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
    The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
    Aug 05, 2010 | Samsung HLN467W 46" Rear Projection HDTV
    My daughter's LCD TV has color vertical streaks
    I believe she had damage the screen TFT (Thin Film Transistors that drive each LCD Red, Blue, Green pixels, there are about a million of them on the screen). The sreen is very delicate. You can ask local repair shop for second opinion.
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://s807.photobucket.com/home/budm/allalbums
    Jul 01, 2010 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
    I have a 37 with a black streak developing on screen.
    It can be problem of LCD panel of your TV. An image of TV screen would help to diagnose correctly, if you can post it here.
    Thanks.
    Sep 14, 2009 | Protron PLTV-37 37 in. LCD Television
    Green screen
    Try doing a "factory reset". This will "burp the baby". Turn the set on and ignore what you see. From the side control panel, push the volume+ and channel+ buttons in synch. This will take you to a base OSD (on-screen display) that can best be compared to the BIOS on your PC. The real goodies are here.
    On the OSD, you'll see "picture", "audio", and "advance". Using standard navigational input on the remote, go to "advance". Tab down to "clear all". The set will appear to turn off, but the front LED will remain blue. The set is re-formatting the on-board memory and will restart in a few seconds.
    Your panel should now restart as normal, but will be returned to factory "burn-in defaults". Your color and audio adjustments will be lost, so you'll have to do some fine-tuning in the regular OSD menu. Cycle power to the TV after you have made the desired adjustments.
    TIP: Perform the factory re-set a second time, then select "picture". Toggle down to "video format". You might find it set to "Pal". Change this, using standard navigational input on the remote, to "NTCS" or "AUTO". Cycle power to the TV after you have made the desired adjustments. The TV will now perform at a refresh rate of 60hz, the American standard. "Pal" is 50hz, the EU and Asian standard. The improvement to image quality will be noticable very soon, as both your eyes and the set adapt to 9.94 hz improvement. NOTE: You may need to fine-tune the TV again after making this change.
    Mar 14, 2009 | Polaroid FLM-3732 Television
    DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
    DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
    Jul 26, 2008 | Televison & Video
    Fault with my Sony LCD tv
    Yesterday it was looking my lcd sony then still has me without image and leaves the green lamp chimney me of power flushedly(passionate) extinguish it i it has not wanted to ignite mas that I can do
    Jan 15, 2008 | Sony KDL-26S2010 26 in. LCD Television
    Intermittent Power Down and Backup
    THE TV ONLY HEAR THE RELAY BUT NO PUSH IN ON NEVER
    Jan 10, 2008 | Sony KV-27V10 27" TV
    Samsung PC J5225 shuts down after 3 - 5 seconds
    It sounds like the tv power supply has problems. you probably should call a service center about a repair.
    there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
    Oct 20, 2007 | Samsung PCJ522R 52" Rear Projection...
    RCA 32V524T TV Logo
    32 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
