Question about Logitech X-530 Computer Speakers
My logitechh x-530 speaker system just quit, all of it. i moved my computor location from across the room and it no longer worked. i have connected and re-connected but no luck.
    Genius:
  • 1,288 Answers
Just try testing the fuse in the 3 pin plug first, off chance it may have gone. Then, if that shows as OK, and you feel confident, remove the back of the Woofer and make sure that the AC wires have not come loose (can't remember if there is an inline or separate fuse in the woofer, if there is, i'd check that
Posted on Dec 29, 2010
I have a set of logitech X-530 speaker for my computer with windows home 7, i have had the front left and front right speaker working properly, however now i cannot get any sound from any of the...
Try to disconnect the input connector of your speaker and touch the input jack of the unit if you hear a hazing sound it means your speakers are working properly but if you don't hear any sound your speakers are bad. Open the speaker unit and check the amplifier section of your unit. If you don't see any burned electronic component inside. Check the wiring of your unit.
To check if the audio of your computer is working. Plug in the input a headset if you hear a sound while you playing a music in your computer it means the audio of your computer is working good.
Jul 12, 2011 | Logitech X-530 Computer Speakers
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
I had my computor worked on and my speaker software has been removed just wondering where i can get the software to get it put back on my computor
Press F8 key again and again when computer shows bios screen during restart, you will get options, select last known good configuration, it should work fine. Else there is no special software for this product. Windows can detect what kind of product it is. Visit the link given below to troubleshoot the issue.
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_alp.php?&section=troubleshoot&crid=439&lt_product_id=211&tabs=1,3,2,5&cl=gb,en&p_search_text=X%20530
May 29, 2010 | Logitech X-530 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
The speakers don't work anymore.
1)Please Check the Power Cord.
2)Please Check the Wire that goes to Computer is working fine.
Jan 21, 2009 | Logitech X-530 Computer Speakers
Front left speaker just quit!!!!
Its not the speakers thats the problem. Its your sound card. Just go and buy a new sound card and the speaker will work.
Jan 18, 2009 | Logitech X-530 Computer Speakers
HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Jan 03, 2009 | Philips HTS3450 System
UK Systems - Scrolling Message Please Wait - Starting Up
Hi, I have a LifeStyle DVD Home Entertainment ctr model # AV 48 Media. The speaker connections in the living room around the center are connected, and working ok. The problem is with the remote connection to other speakers in other rooms. I am using 240 voltage. Please advise how the connections should be.
Hoping to have your response soon,
John Luggya. jluggya55@yahoo.com
Thanks
Oct 20, 2008 | Bose Lifestyle 48 System
No Sound
carefully plug back the minijack for the speaker at the out or spk,
normally the sound card has three ports 1. for MIC 2. LINE IN 3.OUT (SPK) - SPEAKER.
carefully plug the minijack for the speaker into the third one - OUT (SPK) - SPEAKER.
in pluging it in, first put on a media clip on the windows media player and carefully plug in the minijack for the speaker and surely you will hear sound.
UZOWUANYA
e-mail: uzowuanya@yahoo.ca
Feb 11, 2008 | Dell Dimension 3000 PC Desktop
Connecting dvd player to logitech x-530
Well, if you have a DVD-ROM, all you need is a video card with a s-video out to connect to your TV and then you could put your DVD player in your room and play your DVD's from your PC. Another way to do it (without having to buy anything) is to connect the sound of your DVD player to a stereo receiver and then plug the sub into the headphone jacks and the speakers to the sub.
Mar 19, 2007 | Logitech X-530 5.1 Channel Speaker System...
Logitech X-530 Computer Speakers Logo
97 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
