How to fix or disable the touchpad? The cursor jumps around when typing.
    Problem Solver:
  • 22 Answers
There is usually a little icon on your laptop that controls your
touch pad( mine is a finger with a square around it) activate it by holding down the FN key and pressing the button will turn it off /on.. Depending on make and model there sometimes a icon in lower right corner saying touch pad kinda like a grey square and you can make adjustments bye clicking on that.as well as adjust sensitvity
Or under Control Panel/device manager/ mouse /touchpad there are adjustments that can be made there
Look around you will find it Its different for every make and model and year you did not specify yours
good luck
Posted on Dec 29, 2010
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
How do i fix a jumpy keyboard?
This is common for laptops that have a touchpad.
I suspect that you are inadvertently touching the touchpad while typing.
If you use a mouse, disable the touchpad.
If you use the touchpad you can disable "tap to click."
Aug 12, 2014 | Dell Inspiron Computers & Internet
Cursor keeps jumping
I suggest that you scan your computer with RadarSync so that you can find the latest touchpad driver update for your computer. It's a driver related issue.
David
Jul 16, 2013 | Sony VIAO Laptops (Laptop NOT Included)...
Samsung labtop cursor jumps around when typing causing all kinds of problems including highlighting and erasing entire lines or sentences!
Press Fn & F10. This disables the touchpad. You will have to use arrows or a mouse to move the cursor. This helps when you are doing a lot of typing. Press the same keys to enable the touchpad when you are finished typing.
Jan 21, 2012 | Samsung N150 (36725723009) Netbook
On-screen cursor jumps around while typing. When I am typing I end up typing in the middle of previous typed lines. I have a Averatec laptop running Windows XP)
Try using the function key to disable the touchpad. Most times they are sensitive and like to jump when you are typing as your wrists rub or pass over the touchpad.
Dec 09, 2009 | Averatec 6200 Notebook
Jumping cursor on EEE pc.
You're hitting the touchpad with your palms as you type. Either lift your hands when you're typing or temporarily disable the touchpad.
Jul 15, 2009 | ASUS Eee PC 1000H Laptop
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
My cursor on my toshiba laptop keeps jumping when am typing
Ive seen this problem a few times, the problem is that your accidently or inadvertently touching the touch pad as you type. To fix this just disable the touchpad when your typing or put a piece of paper over it. To disable the touchpad it varies on different models but can normaly be done with a button near it, a FN and F1-8 key combo or through the touchpad driver on the task bar. Consult your manual for information on how to disable this.
May 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Jumping cursor when typing
Since you have a logitech mouse, lets just disable the touchpad. You should be able to disable the touchpad via one of these methods:
  1. Look on the top row of keys. You should have one that looks like a little mouse. If you do, hold down the "fn" key in the bottom, and press the key with the mouse on it. That *should* disable the touchpad.
  2. Go to the control panel, and find the keyboard and mouse settings. Digging through the menus, you should find a touchpad. You can disable it through there.
Steven
Sep 17, 2008 | Microsoft Windows Vista Ultimate Edition
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
