Question about Sony STR-DE425 Receiver
How can I use digital media port adapter TDM-iP50 with an older Sony STR DE 425 receiver's RCA inputs? Is there a conversion cable--dm port to RCA?
    Brigadier General:
  • 8,546 Answers
The dm port Can't you just pull the audio from the iPod from its analog headphone jack with an adapter? They're common and cheap.
Posted on Dec 31, 2010
How do I hook up a tv to a Sony D311 receiver
The Sony STR-D311 only has analog audio inputs. If your TV has an analog audio output, use the appropriate RCA cable (2 M/M plugs on each end, usually red and white). If your TV has a headphone jack, use a 3.5 mm to RCA adapter. However, if your TV only has digital audio outputs, you will need a digital to analog audio converter, like this: https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA . You will also need the appropriate analog audio and digital audio cables.
The manual for the receiver is on the product support page: https://esupport.sony.com/US/p/model-find.pl?mdl=STRD311 . The direct link to the manual is currently https://docs.sony.com/release//STRD311.PDF .
I hope this helps.
Dec 04, 2016 | Sony Str D311 Receiver
How can I plug my iPod into this stereo?
Least expensive way is thru a 1/8th" mini to RCA adapter into any of the Sony's audio inputs. If you want "Video" as well, that's another story. You would have to check with "Apple" to see if an adapter is available. No "Dock" port on the receiver. Hope this helps.
Jul 02, 2011 | Sony STR-DE435 Receiver
I just want to fix my ipod on it
I'm glad to provide the instructions to connect an iPod to the Sony Receiver. Depends upon the model, it is possible that the iPod can be connected to a Sony Receiver using a Digital Media Port Adapter. Purchase the Digital Media Port separately, connect the iPod to the Digital Media Port Adapter and then connect it to the Receiver. However, some Receivers are not compatible for connecting Digital Media Port Adapter. In that case, you can connect the Headphone output of the iPod to the Aux/Line input on the Receiver.
Please provide the model # of the Receiver that you're using so that I can provide more information about the specific connections. Thanks for understanding.
Jun 17, 2011 | Sony Audio Players & Recorders
How do I connect my computer to my Sony STR-D915.What if any special cable,adapters,equipment do I need to have all computer sound relayed through the speakers I have ?thanks
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts (*) to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
* http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
YOUR receiver has only analog stereo RCA inputs so you
Feb 11, 2011 | Audio Players & Recorders
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
The digital sound is off after 1 houre str de sony str de 485
It sounds like the receiver is either failing or going into a thermal protection mode.
There should be NO reason why the input source (digital versus analog) should make a difference unless you play the digital sources obscenely louder than the analog ones.
If you suspect heat, you should be able to feel it.
Can you verify that the digital sources ONLY do this?
Mar 01, 2010 | Sony STR-DE485 Receiver
Do the HDMI ports support audio or do I need to go buy optical cables to use them on my STR-DG510
The STR-DG510 carries video only over the HDMI port. Technically, this is a "pass-thru" port. Most older receivers are engineered to operate this way. Why? I don't know. You MUST provide the audio connection using a separate TOSLINK or RCA cable from the program source to the receiver while your video is connected via the HDMI port.
Stick to IT work, MSOFT IT pro. I got smart and bailed out being an IT guru. I got better things to do than screw around with the idiotic nonsense of Microsoft operating systems and applications being a thing of fashion rather than being useful and practical.
Aug 01, 2009 | Sony STR-DG510 Receiver
When I hook up the RCA cables from the Phono to minimal volume
PHONO requires a phono-equipped receiver, which the STR-DE598 appears to NOT be. AUX will not work because it requires Line Level inout. Traditional old-school turntables put out a very tiny drastically-altered signal which needs preamplification to raise it and flatten it out for use by downstream circuitry. THAT is the job of the PHONO section in a preamp or receiver. You need to find a phono preamp or an older receiver to run the TT through. You could slave it to the STR through its AUX then.
Apr 30, 2009 | Sony STR-DE598 Receiver
Getting the best out of my Sony STR DE-475
Yes, it would downgrade.
Simply run an HDMI cable to the LCD from the DVD player. Now, use the digital audio output of the DVD player to run to the receiver. I know the Sony has an optical input which i recommend over the coaxial input as the optical cable doesnt waste any energy as a medium transferring sound since its only light.
Mar 29, 2009 | Sony STR-DE475 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Sony STR-DE425 Receiver Logo
505 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
