Question about Sirius Starmate ST2 Satellite Radio Receiver
My ST2 just died. Still picks up all the channels fine but just doesn't output any sound through the 1/8'' minijack. I've only been using it for 5 yrs on my home system, no car, no boom box dock etc. Sirius tech support went though all the steps wt me but concluded it was probably a burned out amp and I needed to buy a new radio. Is there ANYONE that does "unofficial" repairs of these things? I know its gotta be just some stupid little thing that powers the minijack.
    Scholar:
  • 149 Answers
This could be because of an amp, or it could just be a bad solder joint. Unfortunately, it's impossible to find an amp to replace it because sirius does not release a schematic. So, most likely it's irreparable.
If you would like to see if it's a bad solder, just leave it near a heater and plug it in. If it works, that should tell you that you should reflow your radio. Reflowing is easy, just remove the circuit board from the plastics and heat it up to 800-1000 degrees F with a heat gun. Let it cool and reassemble.
Posted on Dec 29, 2010
Testimonial: "How much would you charge to do this?"
  • Chris M. Dec 30, 2010
    Honestly, I wouldn't attempt because there is a possibility that it is unsolvable. Try the reflow yourself, it's easy. The xbox heat gun reflow tutorials on youtube are a good reference.
  • 3 Answers
I had the Jack start to go. I had a similar problem with the 12v dc power in Jack that was fixed with a bit of solder. I attempted this on the output Jack and had small success. I happened to have an non activated ST2 unit in better shape. Since mine has a lifetime script and I love the unit for many reasons I tried something that appears to have worked.
Inside the case there are 2 circuit cards. One is the receiver (UMA-ST2R). It has the antenna Jack. This was still working. The radio card (UPA-ST2) had the worn jacks also the display and buttons etc.
I swapped the receiver card (lower one in pic) and all worked when I plugged it in and that was it. All channels in a newer case and radio. Four screws on the case and three on the card. Find one on eBay and a small Philips screw driver and problems should go away.
My ST2 just died. Still picks up all the channels - c0c40980-c497-4e53-ae4a-8971ffa5df87.jpg
Posted on Feb 12, 2014
  • Thomas Corrigan
    Thomas Corrigan Feb 12, 2014
    I have had a lifetime script on this since 2004. Its olld but still works and the music has been free now for the last 6 years.
  • 20 Answers
I fixed my on ebay. http://www.ebay.com/itm/400186953938
Posted on Sep 01, 2011
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
Broken audio jack
replace the jack or the circuit card with parts off ebay. see the two cards pictured in my solution at this link.
My ST2 just died Still picks up all the channels fine but just doesn...
Mar 22, 2014 | Sirius Starmate ST2 Satellite Radio...
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
CTS 4200 4 channel CROWN power amp I changed 2 output transistors on channel 1 they were both bad but I am still seeing a fault on channel 1. I tried changing the relay for that channel but the relay...
Try changing the emitter resistors near the parts you've replaced. Also when you change out transistors it's a good idea to change them ALL out..The "supposedly good" ones may be badly stressed.
If the output line to the spkr relay has more than a volt on it the amp will stay in Protect
Jun 24, 2011 | Crown CTS4200 4-Channel Amplifier
Does the alpine 9845rb have a clock display?
yes it does see below
  • CD receiver with built-in amplifier (16 watts RMS/45 peak x 4 channels)
  • detachable face with Quick Search button
  • plays audio CDs, CD-Rs, and CD-RWs including discs burned with MP3 and WMA files
  • Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
  • BBE sound processing
  • two sets of preamp outputs
  • rear-panel minijack auxiliary input
  • clock
  • CEA-2006 compliant
  • CD frequency response 5-20,000 Hz
  • CD signal-to-noise ratio 105 dB
  • FM sensitivity 9.3 dBf
  • warranty: 1 year
Jun 02, 2011 | Car Audio & Video
I have a sharp aquos model number LC 60le81oun how do I set the settings to input 1 ?? I am trying to hook up external speakers and can't get sound if I hook it up straight to the tv but will get sound if...
Input 1 is an INPUT so you can't connect external speakers there and get sound from the television, which is what you are attempting.
Your two choices are the 3.5mm minijack hole that says AUDIO OUT terminal, which is under the Ethernet Terminal and the DIGITAL AUDIO OUTPUT terminal, which is under Input 7. If your external speaker system does not have a 3.5 mm minijack input to accept the 3.5 mm minijack cable then this isn't going to work. There are cables where one end is a 3.5 mm minijack and the other end is an RCA so you can try that and it MIGHT work. Other than that the Sharp televisions are known for not carrying sound over the fiber optic cables consistently so even if you bought a fiber optic cable and connected it between the digital audio output and a speaker system or sound bar there is no 100% guarantee it'll work. It is worth a try anyways.
Feb 09, 2011 | Sharp Televison & Video
Should i need sound card,audio driver or what my mic is not detected on messengers and even i change set up on messenger tools set up.
Yes sound card plus audio driver is needed for microphone to work.
Here is the audio driver link
ftp://ftp.hp.com/pub/softpaq/sp28001-28500/sp28481.exe
Download it and have it install.
here is the details of what to plug in your sound card
line output (usually with a 1/8" stereo minijack). You can feed this into a cassette deck or an amplifier (ideally connected to a good pair of near-field monitor speakers) for playback and mixing purposes. If you have a really cheap soundcard, it won't even have this and you'll have to get your output from the...
headphone jack (with a 1/8" stereo minijack). You can use this for monitoring while recording, but don't use headphones for mixing.
line input (usually with a 1/8" stereo minijack). This is the only thing you should plug any of your musical recording stuff into.
Dec 09, 2009 | HP Pavilion dv1000 Notebook
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
Starmate ST2
Try finding the reset. It's usually a pinhole.
Aug 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Sirius Starmate ST2 Satellite Radio Receiver Logo
462 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
