Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Wont turn on
Last night i was watching tv and then turned it off. today turning on the tv but it just wont do it ive tried everything with and without the remote....
  • falcondc65 Aug 17, 2008
    We were watching the tv today when it just went blank. The tv has a built in dvd player. At the bottom right there are two words that light up when the tv is on ...power and disc. There is a yellow light blinking under the word disc. It will blink three times then off for a few seconds then the cycle repeats. I have unplugged the tv then plugged it back in and nothing. No picture no sound and the remote nor the power button on the tv do not work. Any information would be helpful.
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
SOURCE: TV WONT TURN ON
probably soldering or inverter power bad
Posted on Jun 01, 2008
  • 187 Answers
SOURCE: Green light but no picture, no sound
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
likha
  • 790 Answers
SOURCE: tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Posted on Jun 09, 2009
budmrtn
  • 11361 Answers
SOURCE: i have a toshiba 37 wlt 58 lcd tv . i watched the
Sections of the power supply may have gone out, or it detects short circuits in the backlight inverter board or in the power supply itself.
Those are the two areas you need to check. Look fo bad caps with leaking/bulging top fist in the power supply.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 13, 2010
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
TURNED TV OFF LAST NIGHT EVERYTHING WAS FINE. TURNED ON TODAY - NO SOUND, ONLY STATIC
The tv is on the wrong input. Try running through the different tv inputs with the remote. If you have a cable box make sure its on. Hope this helps.
May 28, 2011 | Toshiba 46HX83 46 in. Rear Projection...
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
My 26' sanyo vizon wont turn on and i dont know why.
I have the same tv. Was watching last night when it turned itself off. When I tried turning it back on the switch just made a click noise and nothing happened. After a couple more tries, it didn't even do that.
Jan 26, 2010 | Sanyo DP26746 26 in. LCD Television
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Screen keeps blinking red
check the menu and see it it hase the same issue if sone one of the main boards are bad.
May 27, 2008 | Philips 42PF9630A 42 in. Plasma Television
TURNED TV OFF AND NOW IT WONT COME BACK ON
the power supply of your tv has a problem,its better to coldsolder the main board of your tv.
May 04, 2008 | RCA TruFlat 27F520T 27" TV
TV WENT OFF BY ITSSELF
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
204 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
