Question about HP Photosmart M425 Digital Camera
I took the memory card our and it will not stay down it says can't format where can i go to get it fixed hpdigital425camera windsor ontario
  • HP Master
  • 1,679 Answers
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
If this does not help, You need to use a Memory card adapter or Card Reader to do so,
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Dec 29, 2010
I took 10 pictures without the memory card so the pictures are on the cameras memory i suppose. I'm now wanting to load them onto my computer but my picture program as well as computer can't see the...
Took a bit to find this this bad news in the manual but what happens now is to get the pictures from the internal memory to the computer as a down load you need to first insert a memory card format the memory card and load each picture from the internal memory onto the memory card one at a time once that is down then you can download the memory card to the computer then you will need to reformat the memory card and then go back into the internal memory erase each one of those images and format the internal memory. Now the GOOD news, you only have 10 pictures. Don't forget to do the formatting.
Jan 04, 2011 | Olympus Stylus 790SW Digital Camera
I just changed my memory card and it said can't format the memory card wouldn't stay down what is the problem and where can i get it fixed in windsor ontario
Don't understand what you mean by won't stay down, but is this new memory card a 4GB or larger SDHC card? If so, it will not work with your older camera. You will need to use 2GB or less standard SD card only. Fortunately, these are relatively inexpensive these days. Recommend checking on Amazon.com.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 29, 2010 | HP Photosmart M425 Digital Camera
Took a few photos, switch off, 5 minutes later switched back on, blank screen but can view playback and menus
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 10, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Card error
1. Ensure batteries are fully charged.
May 06, 2010 | Olympus E-1 Digital Camera
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Formatting Memory Card
this memory card not formatted error is quite famous, I saw it before, but luckily I found the solution, check it out
Fix Memory card not formatted error and recover files
hope that you can find the help as me.
Jan 30, 2009 | Nikon Coolpix S210 Digital Camera
Camera insist on memory full, but card is empty
Press "Menu" Press button to the right (towards a little flower on my camera) which takes you to the "setting" menu. scroll down to "format" right click again and it reads "All data deleted" and then gives you the option to "Format" or "Cancel". Select "Format" and then "ok" and pronto....your memory card is ready to go.
Nov 17, 2008 | Cameras
3110c 1gb "memory card not formatted"
nokia 3110c show the disiply memory cord not formated how to solwe thes prablam
Jun 29, 2008 | Lands Phones
Kodak M853 error message
My first inclination was that maybe the lock on the side of the SD card was on but after you mentioned that it worked in your mom's camera, I don't think that's the case. You may want to check that though. There's a little switch on the side and just make sure that it's switched to the "unlock" side.
The only other thing would be to format the memory card. When you do that, you will lose all the pictures on it. So, if it happens to work in ***********'s camera, I would transfer the pictures you already have saved on there and copy them to a cd before formatting the memory card.
In order to format your memory card, press the menu button, then go into the setup menu. There should be a list of settings. Scroll down to the format option and choose to format the memory card.
I hope this helps :)
Jun 12, 2008 | Kodak EasyShare One Digital Camera
HP Photosmart M425 Digital Camera Logo
47 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
