Question about Bosch 15.0 Amp Brute Breaker Hammer With Service Minder Shock Mounted Handl
Stopped hammer a the bit - Bosch 15.0 Amp Brute Breaker Hammer With Service Minder Shock Mounted Handl
    Top Expert:
  • Bosch Master
  • 76,630 Answers
I am sorry but could you please clarify the problem here, "stopped hammer a bit " gives me nothing to go on to help you.
Posted on Dec 29, 2010
Bosch hammer/drill 11222EVSG
turn knob clockwise till it stops. push button in with a screwdriver and turn it clockwise a bit more then it will wiggle out.
Jan 23, 2014 | Drills
How to take knob off bosh 11236vs
Turn lever to the right until it stops, then push the red button in with a screwdriver and at the same time turn the lever clockwise a bit more until it stops. Wiggle lever and it will come out.
Nov 19, 2013 | Bosch 11236VS Rotary Hammer
Dewalt 25501k powerloss
it need a grease and o'ring maintenance
you need dewalt grease 870889-03 or rotary hammer grease
Sep 27, 2012 | Dewalt Drills
What is the largest demo hammer that the sds floor scaper should be used with? we seem to break the blade with the small 35 lb demo breaker
Worked at a tool rental store while attending college and learned some tricks from the old-timers. To extend the life of flexible blades such as the one used on floor tile removers, use a second shorter blade on top of the longer blade (double blades). The shorter backup blade tends to absorb the extra force making the longer blade last longer before breaking. The length of the shorter backup blade is trial and error, however start with about 3/4 to one inch back from longer. The wide chipper bits tends to break also. The wider the bit, faster to break. No matter what size hammer. Has to do with the bit hitting the stop on the forward motion. Some older chipper hammers that had rubber or spring loaded bit stopper would prevent wide chipper from breaking so fast. Good luck
Apr 28, 2011 | Air Tools & Compressors
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
I can't get the bit out of the breaker
Sounds like the bit bent slightly and as a result jammed into the chuck. Open chuck as much as possible and have someone pull the bit out while your tapping it with a small hammer. The vibration from the tapping might loosen the bit from the chuck.
Feb 28, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Matika hammer drill - bit stuck
The spade bit sold with the hammer drill was actually too large for the hammer drill. We found that the spade bit had over heated (not from overuse or heavy use as only two ladies were using the hammer drill) but because the bit was too large it put too much weight on the drill. The bit had to be removed from the chuck using a hammer and force causing a bearing to come out and the chuck now needs repair. Solution repair the chuck on the hammer drill and buy a lighter spade bit. Then continue jackhammering the cement out of the shower cubicle.
Mar 25, 2009 | Makita Drills
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Bosch 15.0 Amp Brute Breaker Hammer With Service Minder Shock Mounted Handl Logo
97 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
