Question about Brother MFC 8500 All-In-One Laser Printer
Vertical white line on paper. Have Brother mfc 4800
jtuminaro
  • 56 Answers
SOURCE: BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Posted on Jan 15, 2009
SOURCE: My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Posted on May 01, 2009
ryeisenman
  • 9 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
  • 1684 Answers
SOURCE: i get vertical lines on scans and copies when
Check out this page on our web site at:
http://www.ccl-la.com/dirty_scanner.htm This page shows you what to do to get rid of the lines on scans and copies.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 12, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Posted on Feb 25, 2010
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
I have a Brother MFC 8440..the paper has vertical black lines
Try changing the toner, if it's generic that's your problem, and if it's either an old brother drum or a generic you may need a new one. There is also a glass to clean, it's right above where the drum sits inside, 1/2 inch wide across the top. Wipe with a dry cloth.
Sep 14, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 4800. Faxes at receiving end have a line down page
Clean the wire in the drum (remove drum and place it upside down) by moving the blue plastic tab from left to right several times.
It fixed the problem for me.
Jan 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
Cannot replace back panel of my brother mfc-420cn printer
Hold the rear cover so that the top is horizontal and the rear is vertical. Line it up with the hole in the back and push straight in.
Jan 22, 2009 | Brother MFC 420CN All-In-One InkJet...
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
Dec 23, 2008 | Brother MFC-8640D Printer
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 4800 print quality problem
I would try cleaning the drum unit.
Take the drum unit out of the printer.
They recommend that you place the drum unit on a drop cloth or large piece of disposable paper to avoid spilling and scattering toner.
1. Carefully turn the drum unit upside down.
2. Clean the primary corona wire inside the drum unit by gently sliding the tad from right to left several times. (Be careful with the corona wire they are delicate.)
3. Return the tab to the Home position before reinstalling the drum unit. (If you do not position the tab at the home position, printed pages may have vertical lines.)
4. Re-install the drum unit.
5. Close the top cover.
6. Plug in the power cord.
Hope this helps.
Good Luck.
Apr 09, 2008 | Office Equipment & Supplies
Brother MFC 8500 All-In-One Laser Printer Logo
144 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
