Question about Master Heaters BLP375AT
Cannot get my brand new unit started, i am using a 20 lb propane tank. would that be a reason for it not to work?
  • 111 Answers
Push button on back and hold till warm.regulator got pluged while not in use
Posted on Dec 29, 2010
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
I purchased a used Masterbuilt veranda gas grill. The gas regulator fits a small propane tank. Is it possible to replace the regulator so it will fit a large sized propane tank?
Yes, it can be converted to accept a 20 Lb LP grill tan. Contact Masterbuilt Customer Service
1.800.489.1581 to obtain the new hose/regulator assembly.
Hope this helped you and Happy Grilling!
Jul 22, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
My Mr Heater Buddy heater 4000 to 9000 btu unit work fine with 1 lb propane tank but when I connect it to my 20 lb tank with hose it will not stay lit. Acts like there is not enough gas pressure. My 20 lb...
it could be down to the draw off the tank pipe too small or reg is not for a 20lb tank , going to lock out check reg pressure should say on the side , or take hoes and reg off tank , put it back on and turn gas on slowly see if this helps
Jan 30, 2011 | Mr. Heater Mr Heater Portable Buddy...
When commected to 20 lbs tank the pilot light does not stay on; however, when connected to a 1 lb propane bottle everything works propertly. I have replaced the fuel filter, I have tried using different...
The new 20lb LPG cylinders now have what called an OPD Valve. Reconnect to a 20lb cylinder and turn the tank valve on very very slowly, This will help prevent the OPD Valve from locking up the heater's regulator. Your 1lb cylinder is not required to have this OPD Valve.
By the way, this happens quite frequently with LP Gas Portable Grills.
Jan 25, 2011 | Mr. Heater Mr Heater Portable Buddy...
I have a ProCom ML150HPA for propane and would like to use a 20lb bottle the manual states that at least a 100 lb tank is required. With the 20 lb the pilot lights but will not stay liit without the...
The reason for a larger tank is so the LPG can vapourise enough to supply the heater using a smaller bottle it may freeze and not produce enogh gas
Dec 13, 2010 | Procom MN100HPA Heater
What size propane tank do i need with a Mr. Heater 45,000?
Rule of thumb is that you have 100,000 btu's per gallon of propane. This only translates into the length of time you have available in a tank of gas. The problem arises when you consume too much too fast. The gas can't produce enough vapor to continuously run and becomes dormant which is commonly known as "freezing up". You can use a typical (20 lb.)5 gallon propane tank (barbacue size), but it will more than likely freeze up in 2 - 3 hours of continous use. I'd suggest going to the next larger size a 30 lb. or 7.5 gallon size. The best way to work this system is to have two 5 gal. tanks so you can switch one out when it freezes and let it thaw while your using the spare.
Oct 04, 2010 | Mr. Heater Natural Gas Garage Heater -...
Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Jan 05, 2010 | Desa International TB101 Heater
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Master Heaters BLP375AT Logo
69 people viewed this question
Top Master Heaters Heating & Cooling Experts
Gil Shultz
Mike Squire
paulcarew
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
