Question about Brother CS6000i Computerized Sewing Machine
The bobbin thread keeps ending up in a big tangle as I'm trying to sew a simple stitch. Bobbin is loaded correctly, thread tension was adjusted both up and down in number, tried straight basic stitches instead of zigzag or button hole. So sick of E6 and my poor three year old is scared of the angry sounds coming out of me as I try to sew a simple seam, which should have taken five minutes, but has now been going on for an hour and a half! Please help. I have a brand new CS6000i model.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
I hear what you have done .... try this sequence - Unthread the machine fully. Remove the bobbin. Is the bobbin thread the same as the top thread? Is it a Quality thread (yes, cheapie thread can give big issues!!) Do you have several different threads wound onto the bobbin?? Is the bobbin thread wound on quite tight? If you push your finger nail into the thread wound onto the bobbin, it must not feel soft or spongy. Check if there is any roughness / burr on the any part of the shuttle hook. If so, remove it with 800 grade wet and dry abrasive or similar. Put in a NEW needle as per user manual specs (not a 'new' one you used before 'just for a little bit'.!) REPEAT - put in a NEW needle - amuse me!!. Place the bobbin into the bobbin holder (the CORRECT direction - yes there is a Right and a Wrong direction!), thread it ready to put back into the machine. BEFORE you do, hold onto the thread tail and let the bobbin and bobbin case dangle. Thread should slip thru when you give a gentle pull upwards. If no slip, loosen the tension on the tension finger a LITTLE. If it slides down easy, tighten it a little. Fit the bobbin into the machine. Lift the presser foot (this releases the top thread tension discs) Check there are no bits of thread or fluff between the tension discs Rethread the top thread - check the thread path is 100% correct. Hold onto the end of the needle thread and draw up the bobbin thread. Hold both threads, start to sew - check the result. Tip : If you use a different color bobbin thread (same brand etc etc) it will help you to see more easily what is going on. You should be seeing some of the bobbin thread color on the top side of the sewing. If not, INCREASE top tension a little - retry.If there is a lot showing, decrease top tension. Good luck
Posted on Jul 13, 2014
    Brigadier General:
  • 4,088 Answers
Suggest taking the machine back to where you bought it and have them try to help if you are doing something wrong, or replace the machine if it has an internal problem. Good luck!
Posted on Dec 29, 2010
How can I prevent bobbin thread from bunching up and tangling?
First thing to do: install a brand new needle and clean the lint/dust from the feed dogs and bobbin area. Make sure you are using the right needle and thread for the fabric being sewn.
All About Needles
Second thing: remove all the thread from the machine. RAISE the presser foot and rethread from the beginning making sure that it is threaded correctly through every thread guide (consult the owner's manual). And verify that the bobbin is loaded and threaded in the bobbincase properly.
AVOID using old, fuzzy, and bargain bin threads.
Set the upper tension to the midway point between the high & low number (this is the factory standard although every machine may slightly differ). Now perform a new stitch test.
If the upper thread is creating a thread mess under the fabric, the upper tension is too loose. Tighten it.
If the bobbin thread is coming up to the top of the fabric, loosen the upper thread and retest. Sometimes the upper thread tension is not enough to prevent the bobbin thread from coming up. In that case, the bobbin tension may need to be tightened. (Search the internet for instructions for adjusting the bobbin tension. NOTE: bobbin tension adjustments should be done in micro-increments as a small adjustment will make a big difference in the result. Be sure to test after each adjustment.)
The tension is correct when the upper thread and bobbin thread meet and cross in the middle of the fabric. This will change whenever fabric, needle & thread are changed, so a sewist needs to be comfortable with regularly making upper thread adjustments.
One other thing to try is pull the bobbin thread up through the fabric before stitching and gently holding the thread tails when taking the first couple of stitches.
https://www.youtube.com/watch?v=caPzulMMlMU
Jan 25, 2016 | Sewing Machines
Thread tangles underside
First let's make sure you threaded the upper thread properly. It MUST be threaded with the presser foot in the UP position. (this opens the tensions discs slightly and allows the thread to be seated correctly) Sew a test seem on the same type of fabric. If it is now sewing ok... you are good to go. If you still have some problems. Make sure you grasp the threads as you start a seam. Did that solve it? If not.. you'll have to adjust your top tension slowly testing the stitch after each adjustment... tighten the tension until it no longer nests underneath.
Good luck.
Aug 20, 2012 | Singer Sewing Machines
I am using my new brother CS-60001 sewing machine for the first time and I can't stop the bobbin thread from tangling. I feel the machine is threaded correctly, the bobbin thread is tightly wound and...
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
Sep 06, 2011 | Brother CS6000i Computerized Sewing...
How do i adjust the bobbin tension on a tesco ej09 sewing machine? The bobbin thread keeps tangling underneath the material
Before adjusting the bobbin tension (small screw on the side of the bobbin case), try this.
Always thread a sewing machine with the presser foot up as this opens the tension control for the top thread so the thread can be properly seated for control when stitching.
Often what appears to be a problem with the bobbin thread is actually the top thread going loosey-goosey.
Apr 03, 2010 | Sewing Machines
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
My bobbin thread keeps getting tangled and breaking everytime I try and sew....I have tried rethreading the bobbin, taking everything apart and cleaning out the dust and debris, I have adjusted the thread...
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Dec 13, 2009 | Brother LS-2125 Mechanical Sewing Machine
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Aug 11, 2008 | Singer 3116 Simple
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
The bobbin string gets tangled in a big mess and jams the machine
adjust the thread tightness. thread tension might be loose enough. be sure also the the bobbin inside the machine is place correctly! reversed placement would result in bigger mess.
Feb 26, 2008 | Brother XR-65t Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
126 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
