Question about LG WM-2277HW Front Load Washer
LE error on the (WM1812CW) WONT SPIN! - LG WM-2277HW Front Load Washer
My washer did this 5 minurtes ago, it means the load is unbalences [u]n[e]ven if you have to little or too much ibn it, take everything pout, let it spin through then do load again with les sor more acording to previous.
Posted on Dec 30, 2010
LE Wm1812CW WILL NOT SPIN LE CODE
was it making a banging noise befor it stopped spinning could be your drum has dropped and if this is the case its no good any more hope this helps
Nov 26, 2011 | Washing Machines
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Aug 29, 2011 | Washing Machines
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Drum will not spin
You will need to change the rotor and stator,
Jul 21, 2010 | LG WM1814CW Front Load Washer
LE Error code
SOUNDS LIKE LOCKED ENGINE. SEVERAL DIFFERENT THINGS CAN CAUSE THIS ERROR CODE TO BE DISPLAYED.
1ST, USING THE WRONG SOAP WILL CAUSE THIS PROBLEM - USE HE SOAP ONLY!!! - IF YOU HAVE BEEN USING THE WRONG SOAP, BEFORE CALLING FOR SERVICE I WOULD ADVISE YOU TO RUN A FEW SHORT CYCLES WITH HOT WATER ONLY - THIS SHOULD HELP IN REMOVING ANY SOAP RESIDUE FROM THE SOAP SENSOR AND BOOT AREA.
2ND, THE CONTROL BOARD MAY BE DEFECTIVE - YOU NEED TO CHECK VOLTAGE OUTPUTS TO VERIFY.
3RD, BE SURE TO CHECK THE WIRING HARNESS - IT HAS BEEN KNOWN THAT WIRES SOMETIMES BECOME FRAYED AND LOOSE RESISTANCE.
4TH, THE SOAP SUDS SENSOR MAY BE FAULTY AND NEEDS TO BE REPLACED.
Regards
ami-man
Dec 04, 2009 | LG WM1812C Front Load Washer
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Drum will not spin
I unplugged the machine for 1 hour and the computer reset, and it is working fine
Jan 04, 2009 | Washing Machines
LG WM-2277HW Front Load Washer Logo
163 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
