Question about Pool & Spa
Water is pouring out of the side of our boiler in the pump room
    Guru:
  • 46 Answers
More than likely, this would the result of the heat exchanger being corroded (rusted) and having a hole in it. Depending on the model of heater that you have (you did not specify in your question) this exchanger may be replaced, but for the most part, due to the cost of the replacement, it may be best to replace the heater altogether.
There is not a whole lot in a heater that would cause water to pour out. Most older units deteriorate over time due to chemical damage and the exchanger just falls apart.
Try opening the cabinet (make sure that the heater is off) and seeing if you can visually see where the water is coming from and the presence of any rust.
If you provide some additional information about the heater, (make, model, and size) it might be possible to further troubleshoot this unit with you.
Posted on Dec 30, 2010
I have hot water but can't get heating to come on
you don't say what type of boiler you have, but as a guide...
Three port valve may not be operating.
Heating Pump may not be operating.
Room thermostat incorrectly set or not working.
Start with the room stat as it controls the valve and the pump..
More information about your system is needed to help you further..
Apr 17, 2017 | Water Water Heaters
Baxi back boiler. Heating only works when hot water is on, and cylinder stat is calling for heat (Y plan). Is this a problem with room stat?
Turn cylinder stat down turn room stat up y plan valve should move to heating check you have power from stat to valve . It may be the valve not moving over to heating side .
Nov 08, 2016 | Heating & Cooling
Problems whith astoria argenta
Hi just a tip from experience, grind the coffee fine and keep the spout ( where the coffee comes out) very near the cup, while making the coffee.
Kolbrun
Mar 06, 2014 | Astoria Coffee Makers & Espresso Machines
Symptoms bad thermostat
how to replace a water pump in a 2010 jaguar fx
Jan 04, 2014 | Measuring Tools & Sensors
There is no power going to the pump in my boiler
Power to the pump goes via the room stat in turn from the programmer check these out first
Apr 22, 2013 | Water Heaters
Empty boiler
Turn main water off to the water heater, it may be a valve on cold side coming in to shut off. Next turn power off to the heater and drain the tank the drain will be located near the bottom of the tank.
You will need a water hose to connect to the drain to run water outside. Open a faucet hot side to allow you to drain the tank.
Upon reinstall connect the tank up and fill tank and open up hot side on one faucet at a time to purge out air from system before turning power back on. Make sure you have water flowing from each faucet's hot side before turning power back on.
Jul 02, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water is pouring out of the bottom of Rational oven SCC 101 E
theres a chance you have a deffective solenoid staying open causing the water to overfill the boiler tank and passing out the overflow into the quench box and down the drain!
Mar 11, 2010 | Ovens
When I pour the cold water into container it heats the water but it will not pump the water to the filter. What's wrong?
The machine is a gravity brew, pour in another decanter of water until it drips from the sprayhead, when that happens the boiler is full, wait seven minutes then brew you coffee.
Feb 05, 2010 | Bunn VPR Coffee Maker
Replacing the pipe unit
Here's how it works....
An initial short run of the pump draws water from the reservoir into the boiler where it is heated by an electrical heating coil. There are two outputs from the boiler, one from the top runs through a pipe to a steam valve. When the steamer handle is turned, the steam valve opens and steam is piped out through the steam tube for frothing milk. The second output from the boiler is on the underside and is stopped by the normally closed flow valve. When the water in the boiler reaches the right temperature, a sensor switches on the OK light. When the light is on, the user pushes the pump switch and more water is pumped from the reservoir. The pressure in the boiler increases because the pump is trying to push in more water and this forces the spring loaded boiler flow valve to open allowing hot water to run out. As the sump filled with ground coffee is fitted to the boiler output, the water is forced through the coffee and out of the sump where it pours into a waiting cup.
When enough coffee has been poured, the user switches off the pump. The boiler pressure falls and the spring on the flow valve pushes the valve shut again.
------------ The first three steps aren't strictly necessary for disassembly however if you're using a long handle screwdriver then removing the base makes it easier to gain better access to some of the screws.
Step 1. Remove the screw on each base arm.
Step 2. ... then lift and remove the arms.
Step 3. Remove the two screws on the base of the unit. Unlike in this photo I would recommend you avoid resting the machine on its back unless you are sure it has been completely drained. The black plastic base can now be pulled away allowing easier access to some of the screws that will be removed later.
Step 4. Undo the two screws on the top rear.
Step 5. Remove the coffee tamper by pulling and twisting.
Step 6. Remove the three screws. These are anti tamper screws and are star shaped with a nipple in the middle.
Step 7. With these screws removed, the top may be lifted away. The hotplate on the top section is still connected by a couple of thin wires so lift it carefully.
Step 8. To help with shifting the top out of the way, disconnect the hot plate/boiler heater connection. This will allow you to push the top of the unit away giving you the room you need to get inside.
Step 9. Unscrew the electrical safety earth and move the earth wiring out of the way.
Step 10. Use some long nose pliers to pull out the circlip that holds the boiler inlet pipe in place. Pull out the pipe to disconnect it from the boiler once the circlip has been removed.Step 11. Unscrew, remove and clean the diffuser.
Step 12. Remove the two screws . The black plastic underside casing can now be pulled away (plastic tabs need to be pushed aside ). Step 13. Pulling away the plastic underside once screws and tabs are removed.
Step 14. Loosen the four black Torx (star shaped) boiler screws . Water in the boiler may leak out at this point so ensure the unit is upright and a towel is placed underneath.
Step 15. Remove the four nuts (three arrowed) from the underside of the boiler unit.
Step 16. Lift up the top of the boiler assembly along with the steam outlet and place to one side. The two halves of the boiler assembly are sealed with a rubber gasket which should remain attached to the upper housing. Make sure this is properly in place when reassembling.
Step 17. The lower boiler assembly can now be lifted out.
to get more detailed help click this link directly.it has all the required instructions and pictures to disassemble the unit.the model number in the link is bit different from yours but the system is very same so it will help you
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/129-delonghi-ec710-coffee-maker-disassembly-and-repair
click on the link above directly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 23, 2009 | DeLonghi EN680.M
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Pool & Spa Logo
162 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
