Question about Astoria Argenta AEP/JUN Coffee Maker, Espresso Machine
We just purchaced a model sae/jn/jun unit and i need a manual to see how it works. Thank you, Chad
II need a manual too tsmyth@sky.com
Astoria C.M.A SPA SUSGEGANA N.F. 127785
looks like argenta ????
Posted on May 10, 2011
Model number is SAE/2XL and I need a owners operating manual. we bought a used machine but they don't have a manual so,we want to know how the machine works and how to clean the machine. thank you if...
Could you please post the full model number and if you happen to have the serial number as well of your Astoria Argenta SAE-2 Espresso Machine? Thank you I await your reply
Rick
Oct 28, 2011 | Astoria Argenta SAE-2 Espresso Machine
How much oil and what kind of oil should I use in the crankcase
Here is an owners manual for model 316791961 (7.99 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/1012092L.pdf
Parts listing 316791961
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-316791961/0247/1503820?sid=MMLxMerchandizexManualsModelxx316791961
Oil: (SAE 30 3.04 Oz.)
ADDING OiL TO CRANKCASE: iNiTiAL USE
NOTE: This unit is shipped without oil. In order to avoid damage to the
unit, put oil in the crankcase before attempting to start the unit.
The unit is supplied with one 3.04 fluid oz. (90 ml) bottle of SAE 30 SF, SG,
SH oil (Fig. 6).
Thanks for choosing FixYa,
Kelly
Jul 28, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Need ownewr manual
Your OM here:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From your OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
Colder use SAE 10 oil.
Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
It is normal for oil to seep when saw is not in use.
Empty oil tank after each use to prevent seepage.
Page 8 has a pretty good chain illustration, I think mine is clearer for direction.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Electric Chain Saw
Looking 2 reinstate the electronic missing parts so it sautomatic
Yes the autofill is inside the control electronic box . If you know about electronic PCB board you migh need to replace a relay which is welded on the PCB board. Or you have toreplace the whole electronic contraol box which is expensive.
Please remember to vote for a rating for this answer, thanks
Nov 19, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Need manual/schematics for espresso machine.
Your coffee supplier will be able to provide you with one.
www.kaldi.com
May 28, 2009 | Astoria Argenta SAE/JUN Espresso Machine
We Have an Astoria SAE 2 Group and am looking to find the NSF label location on the machine. If i can't find that, how can I show health dept that it is NSF certified ?
On the right side of the machine next to the serial number is the most likely spot for the NSF sticker or tag depending on the model of the machine it may only have an ETL listing.
Apr 07, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Message for Chad
Hi. Your problem is most likely with the magnetron. I am guessing that it is going to need to be replaced. This is almost always the problem. Here is a link on how to test it. http://www.gallawa.com/microtech/mag_test.html
Be sure and do both tests. You will need an Ohm meter (a multi tester will have an setting for testing resistance).
Just please use caution and discharge the capacitors!!! Working on ANY microwave poses a risk for shock if caution is not used.
Chad
Nov 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Older machine needs repair
When you press the dispense button does the needle on the dispensing pressure gauge move up to the green area? If so, most likely your group head solenoid valve is bad. It's located behind the back splash. It's a small black box connected to a metal tube just behind the group head. They cost around $70.
If the needle doesn't move it could either be your pump or motor. Now you're in the $200 range.
Jul 06, 2008 | Astoria Argenta AEP/JUN Coffee Maker,...
Astoria Argenta AEP/JUN Coffee Maker, Espresso Machine Logo
227 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
obsteiner
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
