Question about Peavey SP2 PA Passive Speaker
Need a capasitor for crossover - Peavey SP2 PA Passive Speaker
  • 1 more comment
  • yadayada
    yadayada Dec 29, 2010
    You need to klnow the value of the capacitor in micro farads.
  • hawk5226 Dec 29, 2010
    these # py6i or ev6i or x60 x030
  • yadayada
    What does this mean?
    "these # py6i or ev6i or x60 x030" code?
  • Peavey Master
  • 5,603 Answers
Find them at Digikey.com. Search first for "Capacitor" then select "Non-Polar"
HOWEVER there is a part that LOOKS like a ceramic capacitor but it is NOT. It is a "polyswitch" which is a resettable fuse. Go to the Digikey.com site and search for "Polyswitch". Then select 60 volt in the filter and Radial... see if you can find the item. Also consider opening a second speaker if you have it to get the number off one that is still OK. This is part of a protection circuit and needs to be replaced with exact device.
Posted on Dec 29, 2010
Testimonial: "polyswitch it was thanks hawk"
Crossover schematics
measure it with a fluke or similar multi-meter
Jul 16, 2014 | Harbinger APS12 12 Powered PA Speaker
How to connect subs and mains to the same pv2600
This will depend on your Subs. If they have an inbuilt crossover there will be input and outputs on the rear, with the output marked something like 'tops' or 'Output to HF'
If you have these then it should be a simple matter of connecting yout amp to the subs and then the mains to the output.
If you haven't got a crossover in the subs then you will either need to buy a pair of two way crossovers for the right power and frequency and have these in the speaker wiring or use the amp's inbuilt crossover and run one channel for tops and the other for subs. You will lose stereo but the amp will happily drive a 2ohm load so you should still be able to use all four speakers.
Feb 06, 2014 | Peavey Pv 2600 Power Amplifier
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 | Music
Hello i want to know how many speakers can i conecto to my dbx 223xl crossover 3way
The speakers don't connect to the crossover at all. The number of speakers is determined by the amplifier and the impedence rating of the speakers involved. Perhaps you are not asking for the right information? If the above does not help, please update this with a more detailed description of what you need and I'll try to provide that info as well.
Thanks,
Dan
Mar 27, 2011 | DBX 223xl Active Crossover (Stereo 2 Way...
I need replacement crossover because they got burn
The crossover in these is very simple and if it is burned, likely your speakers, maybe both, the woofer and tweeter have been damaged and need to be replaced. Test the speakers before changing the crossover. You MAY NOT notice the damage until you start driving the speakers again. The voice coil of the woofer is a common thing to fry, and while it may not open up, often it becomes unbonded to the coil form and rubs the magnet pole pieces. The tweeter/horn often wipes out the diaphram or blows the element open. Some of these are piezo horns and they can sometimes survive. These are rated at 100 Watts and if your amp can deliver over 50 watts you have to be careful to not put too much power into these. I have several of the Kustom 10 inch ones and several of the 15 inch ones... Also I have two 15 double stacks and they all seem to use the same crossover. Believe me, the crossover is far from what I would call "special" like the advertisements say. As an electrical engineer I was very disappointed. Anyway, test your speakers as they may be the worst of the problem.
Mar 27, 2011 | Kustom KPC12M / Phonic MAX 1000 Spkr & Amp...
MAckie 1604 VLZ Pro Mixer, running QSC 1850 with jbl's from main outs. I would like to hook up powered subwoofers. What is the correct pathway? kenshireman@msn.com
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Jan 27, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
Alesis Monitor One crossover assembly removal?
The question is WHY would you replace the crossover network?
They seldom go bad... Usually the speakers aree blown before the crossover fails.
Jan 29, 2010 | Alesis Music
Peavey SP2 PA Passive Speaker Logo
454 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
