Question about GE Advantium SCA2001BSS Microwave Oven
My advantium 240 glass plate that covers the halogen lights broke in half while cooking (without getting bumped.) I need to find the part. However, I'm worried that something is wrong...like is it getting too hot, or why did the glass break?...is there maintenance I'm supposed to be doing?
MicrowaveSvc
  • 9047 Answers
SOURCE: Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: cleaning advantium microwave
There are many good suggestions for cleaning and deodorizing microwaves here.
Consult your manual before using oven cleaners.
Posted on Sep 01, 2008
How do I clean the interior walls of the microwave over. Also any ideas about cleaning the glass on an oven.
Posted on Nov 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: MY ADVANTIUM EVERYTHING WORKS BUT THE MICROWAVE.
Sorry our chat session got cut off. It's so quirky...
Feel free to e-mail me at prototech@usa.net but the link to the manual is here:
http://www.microwavedisplay.com/sca2000_sca2001_install_sm.pdf
Posted on Jan 17, 2009
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Posted on Apr 17, 2009
I have an Advantium 240 mounted over the range. There's a little trap door that covers an interior light while cooking. My door gets stuck and I hear a motor run. How can this be repaired?
That's the damper. It has to be closed when microwaving, and open when convection cooking.
See my video and also see the description text here GE Advantium microwave oven clicking noisy SCA1000 SCA2000 for more information.
Please note the phone number in the video is incorrect. See the Web site for more.
Nov 24, 2016 | Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
How do I clean the oven in the Advantium 120
We have the same oven and we use glass cleaner and soft scrub cleanser. If the glass on the top of the oven (where the cooking light is located) is really dirty from splatter, you can use a razor blade scrapper. This is the same type of scraper you would use to clean paint of a window. Our Advantium actually came with a scraper from the factory.
Nov 28, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1000 top rear cooking bulb blown
Hi
Thanks for using FixYa. First please disconnect the power of the main fuse or circuit breaker panel and remove the screw from the side of the light compartment cover and lower the cover until it stops. Now gently pull the bulb from the receptacle. Raise the light cover and replace the screw and then connect the oven with the mains and switch it on.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 25, 2009 | GE Advantium SCA1001SS Convection /...
Black Metal Tray for GE Advantium Oven
I just found one for $33.95
http://www.partstore.com/GetModel.aspx?MfgName=General+Electric&BrandName=General+Electric&ModelNumber=SCA1001FSS001&page=3
Aug 26, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Oven Halogen Lamp
It's pretty simple to replace the light without having to remove the oven from the wall...as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Aug 04, 2006 | GE Advantium SCA1000H Convection /...
GE Advantium SCA2001BSS Microwave Oven Logo
75 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
