Question about Pioneer Audio Players & Recorders
Hello, I own a Pioneer audio receiver SX-311R. The sound will drop out at low volumes, usually from the left channel. It sounds like static or bad radio reception but clears up when the volume is increased. It happens intermittenly and only on low volume. I'd like to repair it. Do you have any suggestions? Thank you for your help. Sincerely, Mariano
I have the exact same problem as Mariano. Did anyone come up with an answer?
Posted on Jan 22, 2011
I am not getting equal sound from right as I am on left. The right is a little less on volume and wattage meter,when I balance it fully to right and turn the volume up, the sound gets static and scrat
Check your connecting terminals on both ends for that channel that the polarity is correct and firmly connected. If you find no problem with that, then swap the connections...if the problem repeats to the other side then the speaker is damaged. If the problem stays on right side then it is the unit and needs to be investigated further.
Dec 22, 2014 | Pioneer Sx-1080 Monster Receiver Beautiful...
Only left channel working on avr 1912
Sounds like a possible amp problem. Probably needs to go in for repairs.
Jan 07, 2013 | Denon Avr-1912 Home Theater Av Receiver...
My Pioneer SX-780 Receiver has very low volume and distorted. Are the output IC Amps bad? They use (2) STK-0050
A little more triage would be in order before you take a knife to it. What source(s) produce the distorted sound? How about test tones? Same? It's sick. Not same? Something else is going on. Have you referred to the manual(s)?
Apr 07, 2011 | Pioneer VSX-D457 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
I have a Pioneer Audio Multi Channel Receiver model SX-316-S and I can't seem to figure out how to hook up my TV and DVD to the receiver so that all sound comes through the receiver
DVD audio straight in from its highest quality audio output. Use the stereo audio output to run straight to the TV for casual watching through TV speakers without the Pioneer involved.
A TV is just a glorified night-light, not a sound source - get its related audio from the Cable Box, ditto the highest quality
Mar 04, 2010 | Pioneer SX-315
I have bad static from my Pioneer vsx 49 Elite
sorry no easy solution as it sounds like the output transistors blew out or the emmitter resistors. you will need a service manual and an multimeter to measure the resistors on or around the audio output transistors they are a low value resistor usually around 1 to 2 watts in size. Do not replace any bad , burnt or discolloered resistors around the audio output transistors as if tou do you might just cause more damage to the output transistorsor audio output stage including the audio driver stage of the amp!!!!!!
Larry Dillon
Aug 27, 2009 | Audio Players & Recorders
Direct TV remote codes for SX-315
hello i have a pioneer sx-315 it plays great but the sub performs badly.they sound is very low.they really need to perform better.if anybody know any sub that work better please let me know.
Nov 20, 2008 | Pioneer SX-315
Pioneer SX-450 Receive: Left Channel is not working. The reason is a short circuit (cable)on an Exi tof the Channel. Thank your.
Hello. Receiver is been repared. I was told that a transistor and some resistors falled aut.
Thank you for assistance.
Regards,
Vladimir
Nov 03, 2008 | Pioneer Audio Players & Recorders
Pioneer Stero Receiver model SX-3700- Static noice when adjusting the volume control knob
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Apr 04, 2008 | Audio Players & Recorders
Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Mar 02, 2008 | Audio Players & Recorders
304 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
