Dark vertical lines on tv screen
Dark vertical lines apearing when screen on a white or light backgroung I've tried my manuals troubleshooting section but nothing seem to work to resolve this problem My areal is a freeview set up in the loft Samsung LN-S4041D purchased in Feb of '07. Two almost verticle fuzzy, grey streaks of slightly different sizes appeared on the left half of the screen about 3 weeks ago. The most prominent one is approximately "1" wide and starts at the top of the screen, descending two thirds of the way to the bottom with a slight curve. Their shapes do not change. The second, smaller one is a lighter shade of grey; almost an 'echo' of the larger streak. . Both appear as if they are dirt on the screen, but I have cleaned it with a recommended product. They are not visible when graphics are displayed. They are most visible if the subject matter is simple, such as a landscape with blue sky above and very little detail below as in a beach scene. They are also not visible if the subject is very busy, as in an extreme close up of a brocade cloth in high def.
  • Anonymous Mar 26, 2009
    I have the same problem with a Samsung 32", Model LNS3238D, LCD TV bought May of 2007.
  • 122 Answers
Looks like lcd panel is off.the cost is abit less of anew tv!
Posted on Mar 09, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Vertical lines on tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
Thin vertical lines on plasma tv
Line, faults & possible causes to both Plasma display & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 21, 2015 | Samsung Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
If under warranty then of course use that.
This is a display problem. One solution someone knowledgeable in electronics can try.
This problem can be caused by a bad connection fitting of the flat cables on LCD controller board. Dis-connect the flat cables from the LCD controller(T-CON) and carefully reconnect them. Try the unit before reassembling the back cover. You may have to disconnect/reconnect several times to show improvements if this is the problem.
Sep 25, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
802 people viewed this question
Top Televison & Video Experts
