Question about Fossil Watches
What r the 3 extra hands on fs 4552 for - Fossil Watches
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
What is the extra hand on fi watch for
Extra hand is for GMT (Greenwich Mean Time).
Oct 17, 2014 | Jacques Lemans F1 Gmt Watch
How do i set the month on my fs-4250
Google (fossil)(Fs-4250)(manual) without parens for month setting instructions.
Sep 14, 2014 | Fossil Arkitekt watch
I am trying to find extra links for the band, it is too tight, I need 2. I have searched all the web sights I can find with no luck. The watch is a Fossil ARKITEKT FS-3003.
You can get links from the maker.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html and you will see a menu on the left.
Under "Product info" you will see "ordering links and bands", click on this and follow the instructions.
Jan 08, 2011 | Fossil Watches
I have a Fossil Arkitekt wristwatch (FS-2919). on of the hands on one of the three tiny dials has come loose and is floating around the face. I probably wouldn't care, but the main watch hands get caught...
You will have to remove the back off the watch (cant take off the face). You MIGHT be able to access the hand from there, but you may have to adjust some of the watch inner movement and that will be risky but you can try.
Goood luck
Aug 21, 2010 | Fossil FS2919 Wrist Watch
I have a Fossil automatic wrist watch FS-4196. Is there an easier way to set the date than to run the hands around until you get to the correct date?
Pull the crown all the way out, it will advance the day by one. it will spring back to the hour adjust position, so you just repeatedly pull the crown out until the desired date is achieved.
Jun 11, 2010 | Watches
I need an extra link and the receiving end clasp for my fossil steel fs 2700 watch. Anyone know where to get?
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care" and then look under "Product Info" on the left and you will see "0rdering links and bands"
Feb 14, 2010 | Fossil Stainless Steel and Leather...
Fossil fs-4167. the small fake diamond in it is stuck on sec hand
You have to open your watch, take out stem completely, then take out whole movement and release the stone. I you have steady hands, nimble fingers and a pair of tweezers, you will be able to refit the stone using Superglue.
Jan 12, 2010 | Fossil FS2920 Wrist Watch
Watches Logo
205 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
