Does the xbox pick up the wireless signal automaticaly in the house or do I need an adaptor?
SOURCE: wireless xbox connection
Make sure you have the X-Box Adapter on the same channel as the wireless access point...If your WAP is not broadcasting the SSID then you will have to manually put it in...
Posted on Dec 31, 2007
SOURCE: verification and signal problems
I am having the same issues. My D-LINK adapter can't even see the network after clean install. It tells me wireless connection is unavailable and it does not see the NetGear Router even when letting windows handle it. Doing a Connection Wizard it sees nothing. Light is on dongle. I have tested the network with my wireless laptop and it works fine. Used static address after a bit of tinkering. Is my dongle caput!
Posted on Aug 26, 2008
SOURCE: problems with xbox 360 wireless adaptor, finding zoom x6 router
For this problem use http://zoom.custhelp.com/cgi-bin/zoom.cfg/php/enduser/std_adp.php?p_faqid=929&p_created=1193678463&p_sid=NcYTzXmj&p_accessibility=0&p_redirect=&p_lva=929&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjEsMjEmcF9wcm9kcz0yNSwxMjcsMTY5JnBfY2F0cz0wJnBfcHY9My4xNjkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PVdpcmVsZXNz&p_li=&p_topview=1
Posted on Jan 02, 2009
webdevil
  • 43 Answers
SOURCE: cannot connct xbox 360 wireless adaptor
Your XBOX 360 adapter should automatically be assigned an address by the router's DHCP server. I think you may be having a problem with your wireless configuration. Check the wireless settings on your router to confirm that it is indeed setup for WEP. If it is setup for WEP on bothe the router and the XBOX and the key is typed in correctly on the XBOX it should work. If it still doesn't however, disable the wireless security on your router, then restart your XBOX and see if it will connect without WEP. Many devices will have problems over WEP and not connect at all. If it connects fine with no security enabled then we will know that was the problem and I would sugest changing the security to WPA.
Posted on Jan 05, 2009
rahul26485
  • 611 Answers
SOURCE: Red Light On Wireless Adaptor For Xbox Live
just do port forwarding in the router and port number of the x box OK try it
Posted on Apr 18, 2009
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
Wireless Network Adapter Xbox 360 (SKWIFIX360): My wireless adaptor on my xbox 360 won't connect t...
1) Reset the router then the xbox.
2) If it still does not work, Change the security code for your wireless on your router. Then connect using that security code on your xbox.
Apr 28, 2010 | Microsoft Computers & Internet
I have just set up my computer with wireless internet. My laptop picked up the signal with no problem. I have purchased an wireless adaptor of the x-box 360 but am unable to connect to the internet. It...
On the setup for your wireless network through your router, you have to allow access for other devices. Your internet provider should also be able to walk you through this process as they did for me when I had the exact same problem.
Jan 01, 2010 | Microsoft Xbox Console
Network adaptor question
you can buy a wireless bridge which will give wireless capabilties. Netgear makes one and others.
but you can hook up with a wiireless adaptor unless you have a wireless rounter or a bridge
Jun 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Cannot connct xbox 360 wireless adaptor
Jan 05, 2009 | Microsoft Wireless Network Adapter Xbox...
Internet
First you need an internet connection, wireless or network cable.
For wireless:
You need the XBox 360 wireless adaptor.
Follow instructions to plug it in, then turn on console.
Go to the Dashboard.
Go to Console Settings.
Then Network Settings.
Then Search for a Network.
When you find your network, select it.
If you have a network code, such as WEP, enter it when prompted.
Now, whenever you turn on your XBox and have the wireless adaptor plugged in, it will automatically connect to your network.
For cable:
Plug in the cable to your console at the back.
Then follow above steps if it doesn't automatically connect you.
To play with mates, you need to purchase an XBox Live Gold Membership.
To do this, you must create an account after connecting to the internet.
To create an account:
Dashboard
Create Account
It will ask you to set up XBox Live and to pick a name.
Pick your name and connect it with a Windows Live account such as hotmail.
Follow steps to input information.
Payment can be automatic to a credit card number or, you can purchase XBox Live Membership Cards at most electronic stores, and input the codes.
You get one month free trial just for signing up.
Now to play:
Find out your friends' gamer tags or XBox Live name just as you made yours.
Push the XBox Guide button in the middle of your controller.
Select Friends.
At the top, add friends.
Input their gamer tag.
When they accept your invite/request, you can invite them to chats and games.
Pick your game, follow the instructions to play a multi-player game over XBox Live with your friends.
Have fun.
Dec 28, 2008 | Microsoft Xbox 360 Console
Connecting to x box live
Yes. You can go into the network settings on your Xbox once it is plugged in and set it up easily. It should recognize your network on it's own, and you just have to tell it to choose it. If you have any WEP security on your wireless network, you will have to enter the code into the wireless network settings on your Xbox.
Dec 03, 2008 | Microsoft Xbox 360 Console
Put the wpa key in for xbox360, says it's connected but green light not coming on my xbox wireless adapter. if i reset the belkin will it pick up my xbox?
maybe. do you have internet connection in your house? if so the wireless adapter should pick up the signal. i myself have xbox 360 live and use a wireless adapter. It also might just be your adapter. lots of people use the ethernet cables that came free with the xbox and plug them into a modem. connection is more fullproof then wireless.
Feb 11, 2008 | Video Game Consoles & Games
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
