My furnace was working last night but when we woke up it was not working. Pilot light was out. Tried to relight but it wouldn't stay lit. Replaced the thermal cuppling. Still nothing
  • 111 Answers
New one is working?Tight? Is it in a fair amount of flame? You'll need a tester ,the thermal coulpling should put out a few hundred millivolts when hot.you can check coil on gas valve with ohm meter.I went on a service call recently where the new thermal cupple wasn't tight.
Posted on Dec 29, 2010
Furnace goes out when blower should start
There is a sensor called a pressure switch that is attached to the area of the blower motor for the exhaust fan. It is bad or plugged.
Nov 16, 2015 | Heating & Cooling
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
Per landlord, need to light pilot
You would smell the gas, so you're probably ok. Lighting the pilot is not too tough, first you have to get the cover off the furnace. Inside you will see pipes and parts. Hopefully on the cover, inside or out, or somewhere inside the furnace will be instructions.
If not, find a knob that has 'pilot', 'off' and 'run' or something like that. It will probably be in 'run'.
Usually, you have to push the knob down and turn it to get it to the 'pilot' spot. When you do, have something to lite the pilot, which will be inside the furnace more, near the burner. The burner looks like a gas stove or oven burner. The pilot place will be at the end of a small tube.
With the button held down, wave something burning around the burner area. especially at what may be the pilot. The pilot doesn't put out much gas, so don't worry about things blowing up.
Once the pilot has lit, hold the button down for a while, at least a minute. Then you should be able to release the button and the pilot should stay on. If it doesn't, you need a serviceman to come. Let the landlord know the pilot would not stay lit.
If the pilot stays lit, move the knob to 'run' or such, and the furnace should lite, if the thermostat is set higher than room temp. If it has been off, and the room is cool, it should lite.
If the furnace doesn't come on, let the landlord know.
Most landlords have service people for this, it was my job for a long time. Lighting pilots was a common chore for me. If you can, have the landlord send one out to show you how to do it.
As you see, it's not all tough, but it's not all easy, either.
Nov 29, 2013 | Heating & Cooling
Pilot light will not stay lit om furnace
No pilot feed or it is dirty and or cob webs may be disrupting flow. Clean every thing and relight.
Oct 21, 2013 | Omega Trane Furnace Draft Inducer Blower...
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
When you first light the pilot works fine after cooker heats up it may cycle a few times and the pilot goes out and then when you try to relight it will only stay lit while the pilot button is being...
Hi there. Try cleaning the thermopile, it must be free of soot or any other form of dirt, the pilot flame should be of good quality, as well as the gas pressure.
Regards.
Aug 02, 2011 | Imperial IFST25 Deep Fryer
I have a york furnace, pilot light is lit but i have not heat and no air is blowing..this happened last night also and this morning i accidently bumped into the furnace with my sons toy and it started...
From what you are telling me here, you have a loose wire inside the furnace. You could try giving it a bump again and it may work. But prbably not for long...
You need to find the bad wire or have someone look at it that can tell where the bad connection is.
Heatman101
Feb 18, 2010 | Heating & Cooling
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
