Question about Samsung SyncMaster 204BW LCD Monitor
My samsung syncmaster 204bw power light keeps blinking and wont turn on.
  • 11,361 Answers
Does it do the same with another PC?
If it is monitor, then please read below
Look for bad caps first:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 29, 2010
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
I have a samsung syncmaster 204bw and sometimes the monitor flashes black for a couple seconds and then comes back on. it will do it and then wont for awhile.
This is an early warning that the inverter board is failing, "powers the back lights behind the screen" eventually it will go. The board must be replaced or repaired.
Feb 07, 2011 | Samsung SyncMaster 204BW LCD Monitor
My samsung syncmaster 204bw turns on and the power button lights blue, but my screen remains black, i then try to turn the screen of but pressing the lit blue power button the screen remains on and will...
It may have dying power supply due to bad caps.
Dec 10, 2010 | Samsung SyncMaster 204BW LCD Monitor
My monitor plugs in blue power button blinks why ?
There is probably a failure of part of the power supply pcb. If the light blinks and the screen is totally dark, this is the likely cause. The usual culprit is decective capacitors on the pcb. See other posts on this subject here. This failure may be intermittant; in other words, it may not always occur.
Jun 02, 2010 | Samsung SyncMaster 204BW LCD Monitor
Samsung syncmaster 204bw will not turn on
Check the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 31, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. The images show for a few seconds and goes blank...turn monitor off and on...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
I have samsung syncmaster 204BE monitor. always
If you are talking about the power light flashing and no picture then its not in sleep mode, the power supply has failed. Check our web site at: HTML clipboard www.ccl-la.com Look in the monitor repair pages. We have a step by step repair guide for this model Samsung. If you don't want to do the repair yourself we do offer a repair service, information is available on our site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Problem with syncmaster 204bw
Hi there.
unfortunately this is not a driver issue. if possible, test this screen on a different PC/Laptop.
it sounds like a problem with the screen itself - meaning you will have to take it to a service centre, or if its under warrantee - take it to the shop you baught it from.
*** NB note: samsun screens normally carry a guarantee of AT LEAST 3 years, and not only 1 Year.
Jun 17, 2009 | Samsung SyncMaster 204BW LCD Monitor
Samsung SyncMaster 204bw....keeps going black every now and then with the power light flashing, i don't understand what is wrong with it :S please help?? i have to restart my system everytime...
Similar problem with Samsung Syncmaster T260 at 1920x1200 on HIS Radeon X1950XTX video card. Black horizontal stripes lasting 1/60th of a second or so every few seconds, then black screen for 2 seconds, then fine again.
I Set the catalyst control center control panel for the graphics card to Alternate DVI operational mode under the Digital panel attributes item. Setting the screen to 1600x1200 also seems to stop it doing this. BUT...it didn't used to do it. Bought it in November, and it didn't start doing this until late January. Go figure.
Apr 04, 2008 | Computers & Internet
Open Questions:
Samsung SyncMaster 204BW LCD Monitor Logo
599 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
