Question about Home Security
My key pad is beeping for one second every minute. the battery is fine and all other operations of the alarm system are working properly. what is causing the beeping?
  • dottiel575 Jan 11, 2011
    managed to fix the problem, like a computer needs at times, I cut the DC & AC power to the unit for about a minute, then reconnected both power sources. As a result, the alarm reset itself and the beeping every minute is gone and the alarm is functioning properly
  • 10,865 Answers
Hello Dottie.... Sometimes this happens when the battery contacts need to be cleaned. Do this. Remove that battery and use the eraser end of a common pencil to clean the battery contacts. Be sure to clean both ends. Once cleaned, be sure to install a new battery. If this does not stop the beeping, the next step is to replace the key pad because it must have an internal solder joint that has deteriorated. Joe
Thanks for choosing Fixya!
Posted on Jan 08, 2011
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
SO bad, and a bad response... I have 2 UPCs one started beeping for no reason, and will not stop...even when plugged into the wall with the battery disconnected... The other one is still silent. SO the...
These beep error codes may help you.
1. Four beeps every 30 seconds (On Battery LEDwill be illuminated)
This alarm indicates that the Battery Power Suppliedoutlets are now supplying battery power as opposed to power from the utility.If the UPS determines that the input utility power is unsafe for your computerequipment, the UPS will switch to battery power.
This alarm indicates that a Low Battery condition hasbeen reached and that the UPS will soon shutdown. Once the UPS transfers to OnBattery operation, it can only stay on battery for a limited amount of time.The UPS will sound this alarm about two minutes before the batteries aretotally exhausted. Once exhausted, the UPS will shutdown and turn off itsoutput power to your equipment. If you hear this tone you should immediatelyshutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPSOFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overloadcondition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detectedwhile the unit was on-battery operation. This tone will continue to sound untilthe unit shuts down.
This alarm indicates that the battery-powered outletsare overloaded.
6. Continuous Tone (On Line and On Battery LEDsflashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault hasoccurred.
Feb 28, 2011 | APC Back-UPS Pro 650 UPS System
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
The car alarm and key pad will not disarm and the car will not start.
Normal system operation - when the burglar alarm is active, the starter circuit is disabled. Is the battery dead or weak in the keyless remote? Also, is the remote you have been programmed for this vehicle? If the answer is 'yes' to both questions, replace the battery in the remote. Otherwise, place your ignition key in the ignition and turn the key to 'run' (or 'ON") wait 5 minutes, the vehicle should start (if the battery isn't dead).
May 22, 2009 | 2003 Hyundai Tiburon
Jeep one year old. Keyless just stopped working. Engine starts for a second then cuts off. Replaced battery in key/remote and still doesn't work. Now alarm sounds if opened with the key the old...
Assuming you have a second key try using that one to deactivate the alarm, if not replace battery in remote. Does lock and unlock work now? you will need to get the remote operational to disengage the security feature that will not allow car to start.
if not disconnect the car battery let sit for 15 min to reset system try again..make sure bettery in remote is installed properly.
Nov 28, 2008 | Jeep Wrangler Cars & Trucks
Quorum Elert
Hang on...I might have a line on the manual. I'll post when I get it.
Dec 16, 2007 | Computers & Internet
Home Security Logo
141 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
