Question about DCS WO-230 Electric Double Oven
I have a DCS Double Oven, model WOS-230SS. All the functions of the oven work fine. However, the display panel is very dim and extremely difficult to make out. What could be causing this problem? Is it for sure the display module or could it be something else. I have contacted the DCS parts center and they have not been able to help on troubleshooting the problem. They did offer to sell me the display module. They indicated part number 239889 at a price of $327.53. I would not like to order this module if in fact there could be something else wrong...like the voltage module. The module is easy to change out, so that is not the issue, it is just the potential for spending money that is unneeded. Thanks for your help. Dan
3 Suggested Answers
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Posted on Jan 21, 2010
Thanks Folks... saved me some $$$ on my DCS-WO-227BK !
Part ordered direct cost $87 vs. part ($140) + labor ($125) from service agency.
Turn off power (50 amp circuit switch in electical panel), removed some screws and replaced part #211696 (DCS EOC DOUBLE DSP) as outlined by duder999.
Posted on Jun 30, 2010
Where can i buy a replacement control display
Hello Friends!
This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem- This control board is no longer available to buy new. Contact FixYourBoard.com at 512-355-1108 for more information. The photo below is from a double oven, but they repair single oven displays too.
Apr 13, 2017 | DCS Ovens
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
Dcs oven display dim - need part #
Jul 19, 2009 | DCS (WOTD-227) Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
DCS wall oven very dim display for settings
typical for gas filled displays. check other postings for same problem for correction. part cost is $92.
Nov 19, 2008 | DCS (WOTD-227) Double Oven
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS Single Wall Oven Model WO-130-SS
Order part #211708 from 1-888-281-5698 DCS Fisher@Paykel new Zealand. Only need philips head screw driver and twenty minutes. This part is a upgrade for lcd only. old part was a three part system, but no need for three parts only lcd screen.
Jul 07, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
DCS WO-230 Electric Double Oven Logo
169 people viewed this question
Top DCS Ovens Experts
ashburton
Joyce Nokleby
ray gallant
Are you a DCS Oven Expert? Answer questions, earn points and help others
