Question about Audiovox GPS
I have a 2007 infinti g35 with push button start i had a remote start installed (model pro-9556c) how do i keep the car started once i get in the car. I put the flog in the slot and hit the push button twice but once i put my foot on the brake it cut off. The installer went over it but i forgot how to do it. THANKS!
jgwhomeequip
  • 1902 Answers
SOURCE: toyoyta mr2 brakes are gone
What part is bad that is leaking? Sounds like you are getting air into the brake line and this will cause a problem with te pedal going to the floor
Posted on Feb 10, 2009
SOURCE: Shifter stuck in park!
you have to take off the plastic all around the gear shifter. You can wedge a screw driver carefully around the edges and pry the plastic off then there is a screw on the shifter take that off and slide the top off and then take off the rubber until the whole shifter is exposed then you will see in the cavity on the right side a little metal round tab on a spring that you have to push in with a screw driver and it will release the shifter. Good luck
Posted on Mar 26, 2009
  • 88 Answers
SOURCE: The battery for the remote key went flat. How to start the car?
leave the ignition on for upto 30 minutes this will then over ride the immpb but change battery in remote much easier check with your local toyota dealer they will tell you the sequence
Posted on Aug 07, 2009
SOURCE: 06 IS 250 ; put foot on brake ,press start button
This just happend to me and I had a jump start and it finally worked. I had a dead cell in the battery and replaced, now it works. However now my windows dont roll down, I was told to take it to a lexus dealership to reset the computer.
Posted on Aug 23, 2009
  • 7 Answers
SOURCE: hit the button twice,truck starts then dies.will
to test this put ur key in the ignition but dont turn it if it starts then its detecting the key and u know as soon as u pull ur key out it wont work its a security bypass issue
Posted on Dec 15, 2009
I have a 2007 chevy tahoe with factory installed auto start. what buttons on remote or what sequence do i push to get truck running?There is a lock button an unlock button a rear glass open button and a...
To get your truck running with auto start first press the lock button and then hold down the semi cicle button for about 3-5 seconds this will start your truck
Jan 28, 2011 | 2007 Chevrolet Tahoe
1988 GTA i have a viper system, and need to bypass the system to start my car, how
open the door turn key to IGN position ON position push valet button once Crank car
Bring to pro to disable the system
Aug 15, 2010 | Viper Security and Remote Start System...
How do I reprogram two remote starters for my 2007 Chevrolet Tahoe?
on the right of the speedo cluster, press the second button down on that set, continue to push until you see relearn remote. once you see relearn push and hold the check button, which is the bottom button on the same set of buttons. Hold it for about 5 seconds it will say relearn active. Then you hold down the lock and unlock at the same time on the remote for about 5 seconds, you will then hear a beep. Do the same with the other remote. Then its done! to close out just push the same button you started with, second from the top.
Nov 10, 2009 | 2007 Chevrolet Tahoe
Can I get a remote start for a 2007 G35X?
Yes. You can buy them and have them installed at best buy.
Nov 06, 2009 | 2007 Infiniti G35 Sedan Sport Sedan
I did self- oil change for my 2007 G35, but how
Look in your self owners manual...they are all different.
Jul 17, 2009 | 2007 Infiniti G35 Sedan Sport Sedan
Gas tank door not opening
Have you looked in the trunk on the side that the gas tank is on? There may be a fuel release switch. Couple of other things to try is to unlock all your doors from the inside of your car and/ or try pushing in and out on the gas door over and over until, hopefully, it triggers the device. I hope that will help you. I will keep trying to find the answer. Let me know. Have a great night.~MWD
Mar 26, 2009 | 2004 Infiniti G35 Sport Coupe
Infiniti G35 will not start
try google for this information and if not helpful you may have to call a dealership or garage for help
Mar 21, 2009 | 2007 Infiniti G35 Sedan Sport Sedan
GPS Logo
26 people viewed this question
Top Audiovox GPS Experts
Marvin
Marvin
Will Halftowaite
Are you an Audiovox GPS Expert? Answer questions, earn points and help others
