Question about Norelco Arcitec Electric Shaver - Gray/Black
The heads on my arcitec get dull in a few months in spite of daily dry cleaning & weekly wet cleaning. Is there a cleaning solution that I can use for wet cleaning that also lubricates the blade & protects it from getting dull so quickly? Am I able to do this without purchasing the cleaning base? Where can I get a good cleaning base?
  • 1 more comment
  • Lyndon Winn Jan 03, 2011
    So I need a cleaning base & can use any brand of solution in it as long as it contains kerosene? Or I can use any brand of cleaning base?
    You answered part of my question but I'm not clear about the issue of where a cleaning base is purchased? Did you mean that any cleaning base will work & it doesn't have to be designed for the arcitec? Or any cleaning solution will work in the base designed for the arcitec?
  • 944 Answers
No You have to buy a cleaning base.The cleaning base contains the Lubrication oil which protects it going dull.You can buy any brand.It contains kerosene content in it.Buy it in barber shop they have it too.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 03, 2011
I have used philips triple head razors since 1969, all worked well however my 18 month old RQ10 arcitec shave head only lasted 16 months, it dosnt have the self sharpening feature or detail cleaning...
Philips suggests that you change the heads on your shaver every 12 months. This is the life expectancy on newer models. There are not any other options but to change them as needed.
For replacements, see shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Jun 13, 2011 | Philips Health & Beauty
It does nto cut like it use to. The blade is only 6 months old Whats the best way to clean it. It seem to be cutting with only 1 of the triple head
The Arcitec shavers have a poor design which makes it difficult to clean well. The blades can not be removed from their combs, therefore, the only way to clean this is by running them in a cleaning solution. Norelco makes a shaver cleaned that can be used for this. It is available from shaveroutlet.com at the link below. Rubbing alcohol can also be used.
http://shaveroutlet.com/shaver-accessories/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
Simply fill a container about 1 inch deep with the cleaner and then stick the shaver head down into the liquid with it running. Run for several seconds, remove and repeat several times.
Note that if your shaver is badly clogged, this still may not work that well due to the poor design of the shaver heads. If you require replacement, you will also find them at shaveroutlet.com. See link below
Dec 14, 2010 | Norelco Arcitec Electric Shaver -...
Can not get blades out of head to clean blades & foils
The blades can not be removed from the head assembly on Arcitec models. This is the way they were designed from the manufacturer.
The only way to clean them is to rinse them with HOT water or soak them in mild liquid like rubbing alcohol.
If that doesn'tget them clean, you will need to replace them. You will fin replacements at shaveroutlet.com. See link below
Oct 12, 2010 | Norelco Arcitec Electric Shaver -...
How long should heads last on Norelco Arcitec razor
Norelco suggests changing the shaver heads every 12 months for best performance. If you need to buy some, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Aug 20, 2010 | Norelco Arcitec Electric Shaver -...
How do I remove the heads for monthly cleaning on the 1060x norelco arcitec
On link below tells you how to clean anr remove the head from your shaver. It starts on page 22 to page 26.
http://www.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jul 11, 2010 | Norelco Arcitec Electric Shaver -...
Cleaning the blades of my Electric razor
The smell that you are noticing is a mixture of decomposing skin particles, skin oil and hair. This is because you are not getting the blades clean enough.
Philips (Norelco) has been introducing all of their shaver with the ability to clean them with water, however, this is not a very good way to clean them because the oil in your skin that collects on the blades does not easily clean out with water. If you must clean with water, make sure the water is as hot as will come out of your faucet. A better way to clean it is with rubbing alcohol because it works better and will help kill germs which may cause smell.
Of course, the best way to clean the shaver heads is to remove them individually and brush them out thoroughly. However, Philips made it impossible to remove the blades on the Arcitec models. The Arcitec modelsare simply designed very poorly for cleaning.
If you are unable to thoroughly clean the heads, you may elect to replace them. It is suggested that they be changed every 12 months. You will find replacement heads at shaveroutlet.com. See link below
Mar 18, 2010 | Norelco Arcitec Electric Shaver with Jet...
How i clean my razor
I have this razor as well. Just flip the heads open, dump the hairs in the garbage and rinse the heads (while open) under hot water. Keep the heads open until dry and close on up.
May 20, 2009 | Norelco Arcitec Electric Shaver -...
I80 black cartidge not printing
get a q-tip and wet one end in water.  run wet q-tip along head a few times.  then take dry end and run along head again to dry it.  then run wet end again on the absorber side of head.  then dry with dry end.  replace parts, do a deep cleaning, and try a test print.
Apr 27, 2008 | Canon i80 InkJet Printer
Norelco Arcitec Electric Shaver - Gray/Black Logo
121 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
