Question about Dell Latitude D510 Notebook
I have a Dell D510, when I login in I have problems with the keyboard, I type one letter and the screen displays another , always seems to be b and n.s also the screen flips upside down and this then starts the tool bar functions appearing on the screen, ie intenet connection, clock , volumes control, etc etc etc it's doing my head, any suggestions....
    Genius:
  • 1,288 Answers
Just out of curiosity, go to Run and type OSK. This will bring up the on screen keyboard, try typing and see if that brings up the "wrong" characters. This would eliminate the keyboard or prove the keyboard is having issues. You can also attach a USB keyboard and double check with that.
If it happens again, disconnect from the internet (make sure no connection is active) and try again, if it fails to reproduce the problem, you may have a virus
http://www.exterminatelab.com/remove-protoss-virus
If it is a virus, chances are it is allowing someone to remotely access your computer and producing these errors (probably unlikely but..)
Please try the above and then get an online virus scan to eliminate this possibility
Posted on Dec 29, 2010
Samsung p6800 screen keyboard displaying wrong characters
I could be wrong but it sounds like your keyboard layout is set to swype instead of qwerty. On the bottom left of the keyboard is the setting option.
Dec 01, 2013 | Samsung Black Leather Case For Galaxy Tab...
Dell D510 still on dell display
Yes, you either have some corrupt or missing boot or system files. Run the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 02, 2012 | Dell Latitude D510 Notebook
I have a laptop Inspiron dell 1525 and the letters b and n does not work. So I cannot type my password. Can you please help.
While on the log on screen, in the lower left corner, there should be a blue square with a circle in it. Click that and enable the "Type without the keyboard" an on screen keyboard will appear, and click the letters on that for your password
Apr 20, 2011 | Dell 0Y3740 Keyboard
I have installed a new external keyboard (Kensington) for use with my Acer Travelmate 4670 laptop, using the XP auto drivers. However since this instilation the laptop keyboard settings have changed, the K...
There is a possibity in the system to change keyboard-type (not language): Start/Configuration/Keyboard - choose the right type. I think that the system still things the external keyboard is atached whils you're uising the built-in one - which seems to have different keycodes, causing this problem
Aug 11, 2010 | Acer NSK8458AN Keyboard
D510 lattitude. Keyboard letters typed,not ones that come up
If the characters at issue are the UIOPLKJM then press Fn + Numlock to turn it off
If other letters are effected Like " and - then go to Regional and Language settings in control panel and ensure you have the correct keyboard/language selected on all 3 tabs
Oct 06, 2009 | Dell Latitude D510 Notebook
Dell laptop keyboard misses letters
I had a similar problem and it turned out to be excessive heat from the battery. Try running the laptop on ac without the battery as a test.
Sep 15, 2009 | Dell 0Y3740 Keyboard
DELL D510 KEYBOARD
Your alt or ctrl key is stuck. So the keyboard is running different shortcuts.
Jun 22, 2009 | Dell Latitude D510 Notebook
Dell xps m140 types two letters when only want one-example twpo ;letters
Likely to be crud under the keypads - particularly if the letter-combinations are always the same: I had the same problem on my notebook, and fixed it by using a pin to 'plough' the gaps between keypads for hairs. Blowing / vacuuming might also help.
Feb 22, 2009 | Compaq Keyboard
Keyboard & Mouse Problem
Seems like you Ctrl-key is pressed all the time somehow.
Make sure that none of the Ctrl-keys is stuck.
If you try another keyboard, everything should work fine, so just check your keyboard. Maybe you need to replace it.
Apr 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Latitude D510 Notebook Logo
111 people viewed this question
Alun Cox
