Question about Toto Home
Hi, I have a new home with toto toilets 1.6g which leave water particles on the seat when flushed. Any ideas?
    Problem Solver:
  • 9 Answers
This has been seen on other brands as well. due to the lower consumption the manufacturers have had to create a stronger and quicker flow of water to flush the toilet. this has created a splashing effect when the first lot of water is delivered to the bowl. i have not heard of a solution to this problem other than closing the lid before flushing. i shall bring it to the manufacturers attention.
Posted on Dec 29, 2010
My Toto toilet runs after a flush. If I turn the water supply off for a day or so it will stop running but will do it again after a couple of days
If your Toto toilet has some sort of flapper, it may not be seating properly or may be defective.
Jul 30, 2014 | Toto Home
How to stop Toto toilet running? After flush, bowl fills up completely and water continues to run. Jiggling the handle has no effect because cap at end of chain is fully seated. Brand number: Toto...
1. CUT THE WATER OFF AT THE WALL 2. PURCHASE REPLACEMENT INTERNAL UNIT FOR 10 BUCKS AT WALMART 3. INSTALL IT WITH THE INSTRUCTIONS PROVIDED 4. PROBLEM FIXED FOR 10 BUCKS
Jan 26, 2011 | Toto Home
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
My toto toilet has both 1.6 gal and 6 gal flushes. the short flush doesn't go down.
I am not a toto expert but i think i understand the gravity control toilet concept.A gravity flush tank type toilet flushes do to the force of water traveling from the tank to the bowl in a small passageway and forces the water in the bowl towards the integral trap in the toilet.In other words the water isnt dumping quick enough or the passageway is restricted.,My guess is the flush valve isnt dumping all at once.
Dec 01, 2009 | Toto Aquia II Dual Flush Toilet
Increase water in toilet tank-low flush Toto toilet
Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
Nov 11, 2009 | Toto Ms874114sg-12 Carlyle Toilet With...
Hello - my toto toilet seat broke where the bolt holds the seat to the toilet
well you can go to home depot and get your self new seat with bolt or you can buy the screws for it
Aug 10, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
Flush problem with toto toilet
If your hooked to city water it can be cause of the high water pressure comes across and keeps flapper from seating rite. Take a empty plastic bottle,cut it in half long ways. flush toilet then place plastic bottle between fill valve and flapper,trying to devert water away from where flapper seats. good luck.
Jul 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
TOTO WASHLET LEAKS!
from where?? If it is leaking on to the floor from the base of the toilet you need a new wax ring installed,,, if the water is comming out from where the tank bolts to the bowl you need to get the proper kit since it;s a toto they are one of a kind and don't have any universal kits that will work, call or e-mail toto tell them you need the tank to bowl kit, might as well tell them to send the flush valve also and just do the whole thing good luck
Feb 20, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Our toto toilet wont flush the water down. We plunged it to no avail, then we ran drain clearing baloons it wouldnt clear out. we keep removing the water with plastic pots. So we can try something else....
Sounds like something is either in the bowl stuck or down in the waste line. I would probably pull the toilet and pour water down the waste line to see if it backs up or set the toilet up on something and pour water into the bowl to see if it comes out. At least it will help to find out where the problem is. Have you lost anything recently that might have fell in the toilet. Did something come off of the plunger and get stuck in the bowl?
Feb 19, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
Home Logo
123 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
