Question about Bosch Dishwashers
Bosch SKT5102/GB - The cycle is not producing any water into the dishwasher. Have tried the filter and ensured that the water is on.
It could also be the microswitches on the pressure chamber.
Posted on Aug 04, 2011
I had the same problem..inletvalve broken.costed me 11 euro to fix it.partnr in holland is:857950
Posted on Jan 22, 2009
I have A bosh SKT 2052 Will not fill up to start the cycle
see the following causes:
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher) see diagram
2) faulty float switch, test for open or faulty.
see the diagram attached.
God bless you
Jul 11, 2012 | Bosch 22 in. SKT5102 Free-Standing...
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
My thermador dw44zs dishwasher: drain pump runs continuously when turned on even when the door is open. I can't seem to reset the cycle to allow for water to come into the dishwash
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 0426 and 0424. You can also remove 0418 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. If the d/w is connected via a sealed spigot to the sink, remove the grey hose and unscrew the spigot adaptor from the sink and ensure there are no blockages. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety, so check valve, hoses etc for leaks. You will have to manually clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large towel and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=DW44ZS%2f21&ESHOPTYPE=S
I hope this helps, Good Luck.
Jul 13, 2010 | Thermador DWU244 Dishwasher
No water filling the dishwasher.
The circulation pump is possibly leaking and has activated the flood safety, if you can get the unit near a sink and tip it you may find water coming out from the frame area. I would suggest if this is the case that you contact an expert such as BSH home appliances as these units can be quite tricky to work on if you don't have any experience.
Hope this helps.
Jul 09, 2010 | Bosch 22 in. SKT5102 Free-Standing...
Dishwasher doesnot drain
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
SKT5102/gb1 - not pumping out
I had a problem that seems to be related, but it came out that the pump was blocked. I had service to open and remove a small plastic clip that had came into the machine accidently. I do not recognize that water was pumped back as you explain but if the water is not emptied may be this is the result...
Jul 24, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Dishwasher wont progress to next step
Does after the manual moving to the next step, the dishwasher complete the cleaning process properly ?
May 16, 2007 | Bosch 22 in. SKT5102 Free-Standing...
Dishwashers Logo
230 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
