My internal speaker is not working when ever head phon is ok.
    Sergeant:
  • 169 Answers
Then you have to buy another speaker for your Internal speaker the Old one is bad.
that is the SOLUTION...........
remember to Rate me
Posted on Dec 29, 2010
How do I get my speaker to work I plugged in headphones and now the internal speaker will not work
Most times they do not work simultaneously by design. Try unplugging your head phones and the internal speakers should work.
Dec 03, 2014 | Nextbook Next3 tablet
No sound on radio or CD,speakers working nice but dont make any sound
Possible damage to radio output ic if no audio. Output failure is usually due to shorted speaker lines either together or to ground. You can check your speaker lines at head unit and they should have approx 6v dc on +&- lines each channel. If this is not present then most likely is
output failure, if ok then is internal fault possibly with vol control ic or
power supply.
Mar 16, 2014 | Clarion Car Audio & Video
I have use skype sudnly my head phone working stop no head phon and speakar plugged in pls solve my problem
Check your audio driver is working by playing an CD audio disk.
If you have still have a problem then reinstall the audio driver.
If the audio is OK then the audio setting in Skype in wrong.
Open Skype - Tools - Options - Audio settings then in Speakers select your audio device then tick Automatically adjust speaker settings - click Save
Apr 17, 2013 | Computers & Internet
Amplifier head is working but no sound from speakers. Head tested with external speakers and is OK.
A simple test is to connect internal speakers across an AA battery (for about half a second) & listen for a click as battery is connected & another as battery is disconnected.
If this does not happen, check the internal jack plug connection & its connection to the speakers.
If OK, then you can test each speaker individually using the same battery across each in turn.
If this advice is helpful, I would appreciate a rating.
Apr 10, 2011 | Hartke VX3500 Bass Guitar Combo Amplifier
My alpine cda-9886 restarts when i turn it up to about 22. i have no idea how loud it goes. i bought this refurbished from overstock.com about 3 years ago. its becoming annoying now.
the unit may see a short in one of the speakers that is causing the transistor to protect itself by shutting down. Try changing the balance and fade settings to listen to one speaker at a time. If any speaker isn't working, that would be the one causing the problem. If you disconnect the speaker and the problem resolves, the speaker is bad. If the problem doesn't resolve, the problem is in the wiring or an internal short in the head unit. In fact, you may want to start at the head unit and disconnect the bad channel from the head unit. That way you can discover right away if the short is internal. You can even disconnect all the speakers at the head unit and turn up the volume. If it cuts out, it has to be an internal short. If you're good with electronics, you may be able to find the short inside. OK?
Dec 07, 2010 | Alpine CDA-9886 Car CD/ MP3 Player
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
Head phon simbol
you need to replace head jack of your mobile
Apr 28, 2010 | LG CU500 Cellular Phone
DELL LAT INTERNAL + EXTERNAL NO SOUND
assuming headset is right connector, right? and they work elsewhere? that's the only reason headsets don't work, is that the jack is incompatible with the socket for speakers..
Feb 21, 2008 | HP Compaq Evo n610c Notebook
Problems with speakers and microphone on 6515
try plugging the ear bud into the bottom an unplugging it again it worked for me.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
