Question about Reddy Heating & Cooling
Awill not pump diesel to burner to ignite - Reddy Heating & Cooling
  • 1,476 Answers
Jbtbrd1,
You have a classic reddy heater problem. I have at tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to go to get the parts to solve it.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Dec 30, 2010
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
How do I wire a Beckett 12v diesel burner? I have a Beckett 12v burner igniter with a fire eye, a high limit switch, and a flow switch. This unit came with all the wires cut and missing a t stat and...
first do you have a fuel solenoid???i am a burner tech for thirty plus years.fuel solenoids are mounted on the fuel pump.flow switch.high limit switch and thermostat are connected in series to feed the fuel solenoid.
Aug 16, 2013 | Briggs & Stratton Pressure Washer...
Smokes bad when burner kicks on
Hey mate,
What brand of burner are you running? I am a Karcher Tech but they all work on the same principle,
Your burner is getting to much diesel/kero, most have little flow swicthes on them to tell them to pump fuel or spark when there is water present in the burner coil, if this switch is faulty or getting a faulse reading then it will tell the unit to pump fuel when it is not needed and this will cause very excessive smoke for the first few mins when the burner kicks in...
If you have the excessive smoke continuously(even after 10 mins of continous use then it is probable that your fuel pump/system is running to rich, these units need regular servicing and adjustments as fuel nozzles/components wear,
There is alot of precise adjustments and checks on these units and i would reccommend getting it checked by a qualified tech, as when there is heated fuel and spark these units can be dangerous!
Hope this helps
Regards
Brad
Feb 03, 2010 | Northstar Electric Wet Steam & Hot Water...
Just bought a used karcher hds 500ci every now & again lots of smoke belches out burner is this a bad sign ? also cant seem to get the chemicals to pick up any tips
you burner assy needs to be cleaned , spark electrodes properly gapped and the fuel pump pressure set , the chemical pick up often gets clogged , and the chemical valve ( pump side becomes jammed ( a small ball bearing jams in the seat )
also clean out the diesel tank and clean or replace the fuel filter , if the smokes is white thats caused by water in the fuel , black smoke is too much fuel going to the burner assy or your ignition electrodes not igniting it
Nov 15, 2009 | Garden
I have an old 1973 Mac 1199 Intertherm propane furnace The burner will come on and it takes a long time for the blower to come on Sometimes the blower wont come on at all and after awile the burner will...
Replace the fan limit switch. It is sometimes mounted in the ductwork and sometimes just below the ductwork in the furnace cabinet. Note where the little arrows are pointing to on the temperature scale so you can set the new control to the same as the old. Usually this control is made by Honeywell and may have three wires going to it.
Oct 20, 2009 | Intertherm Heating & Cooling
We have a Landa with a diesel burner. The problem
There is a screen in the tip of the spray nozzle for the diesel. Remove the tip and clean the screen. Your getting a explosion because diesel is pooling in the coils and igniting when conditions are right (air/fuel mixture). There is also a screen in the diesel pump. Remove the pump and clean it also. When you split the pump the screen sits between the two halves. Hope this will help.
Mar 31, 2009 | Garden
Whirlpool super capacity 465 / gas oven won't light
now you say your top burners aren't lighting well either have you noticed any difference in the flame height if you turn all the burners on all the way
Jan 17, 2008 | Ovens
Tappan gas kitchen oven will not heat
Almost always a weak oven igniter. Remove oven floor by removing 2 screws at rear of floor. Remove flame spreader from burner, if it has one. Turn on oven and see if igniter gets red. It's the caged thing on burner tube. If it does but doesn't light gas, replace igniter. UNPLUG UNIT FIRST!!
Put dishwashing soap on threads of 2 screws holding igniter in place. This will allow it to come out easier. Do-not use oil. It will make your oven smell like a diesel truck.
Remove screws. You will have to remove drawer in front. Underneath you can fin wires from igniter. These will be cut at igniter and connected to igniter with enclosed wire nuts. The 2 wires to igniter go either way.
Nov 22, 2007 | Tappan TGF320 Gas Kitchen Range
Heating & Cooling Logo
23 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
