Question about Garmin nuvi 200W GPS Receiver
The power and mini USB connector on my Garmin Nuvi 200 has gotten loose and it will not hold the connection through the power cord without being held by hand. Is there a repair for this?
USB connectors are too fragile for the constant in-out service they get. But I have solved the "loose USB" problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Posted on Feb 17, 2011
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
My garmin won't work while the power cord is pluged in.It shows a picture of a computer and a garmin
Sometimes this is caused by wear in the mini USB socket that the power cord goes into. The plug appears to be in fully but it's not. Pushing it in further may solve the problem.
Feb 24, 2011 | Garmin nuvi® 200 Car GPS Receiver
Can not find a USB slot in my Garmin Nuvi 200
I can help you update your Garmin Nuvi 200.
Here is a picture of where the USB cord plugs into your nuvi:
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 21, 2010 | Garmin nuvi 200W GPS Receiver
Can't connect garmin nuvi 660 to PC USB
Your Nuvi should be Off before connecting....
My Nuvi came with a patch cord that connects from Nuvi to laptop
its a usb cord, same usb cord you find for cameras
Your computer should see that a usb cable is connecting
go to.... www.MyGarmin.com and update maps
Mar 24, 2010 | Garmin Nuvi 660 GPS Receiver
USB connector in the back is loose and will not
If the connector in the back is loose, its not a Nuvi 350. A nuvi 350 has the connector on the side. In any event, please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
We have a nuvi 200. We can't find any cords or
I can help you fix your Garmin Nuvi 200W.
You can use the mini-usb to usb cord from many mp3 players or cameras with your garmin nuvi.
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
Jul 11, 2009 | Garmin nuvi 200W GPS Receiver
Will a power cord for a Garmin 250w,200w,270,260,250,&200 work on a 255 Garmin GPS
Yes, They all use the same mini-USB connector, same AC wall charger and same DC car charger.
- Jim
SHARCNET-USA
Mar 12, 2009 | Garmin Nuvi 255 GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Repair usb power male connector snapped off
You can buy a mini usb cord from any computer shop. You can also use one from a digital camera if it has a mini USB slot.
Oct 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
745 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
