I think you're a little confused LUNISOZZI. Allow me to explain.
The term Prescott is a type of CPU. 533 is the (FSB), bus speed that the CPU can run at. There is no driver needed for the Intel Pent 4 Prescott 533 CPU. When updating windows there may be a revision update for the Pent 4 Prescott 533 CPU listed in windows update to the left under hardware. If you're CPU is not beeing seen by windows correctly than check windows update. If you're CPU is not working in on the Asus board, than remove the CPU & check the connecting pins on the CPU. One or more may be bent or broken. CPU may not be completely seated. Thermal grease was not added or too little added between the CPU & heat sink assembly.
Why don't you explain what it is that the CPU is or is not doing?
What is the motherboard not seeing? or windows ia not doing?
I can find a solution if you can explain.
Mike
Was this solution helpful? Show your Appreciation by rating it:
