The mouse is 'jerky' and all over the place. It's wild!
  • graeme ian hunter Dec 29, 2010
    Wireless mouse/ balled mouse or IR mouse?
  • 27,725 Answers
Make sure you have the correct mouse selected control panel mouse hardware
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty or you
might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Posted on Dec 29, 2010
Ideacentre mouse and keyboard lockup
There are some basic steps that you can take to make sure that your wireless keyboard and mouse have the best chances of working.
First and foremost, replace your batteries.
This is the leading cause of failure. Strong batteries are vital if your wireless keyboard and mouse, including Microsoft, Logitech, and other brands, are to work correctly.
Weak batteries can be frustrating to deal with. Sometimes the mouse or keyboard will work fine, and sometimes they start acting odd.
This is where the jerky and slow motion problems can show up. The problem is that Alkaline batteries can provide plenty of energy at first, even if they are worn down.
After a few minutes or hours of use, however, they lose their capacity and the jerky problems can start up. You may even deal with it, then walk away from the computer for the rest of the day (such as leaving your office).
While you are gone, the batteries regain some of their capacity. The cycle repeats itself until eventually the keyboard or mouse do not work at all.
Another common problem is that the receiver for the wireless keyboard or mouse can be too far away for them to work. I have personally seen cases where the mouse works if used on one side of the mouse pad, and not the other.
This was due to the distance of the mouse from the receiver being too great when on the far side of the mouse pad.
The same can be true of a keyboard.
This will also cause the same jerky motions to a mouse, and missed keys on a keyboard.
The solution to this problem is to move the receiver closer to the keyboard and mouse. If the receiver is of the USB fob type (similar in shape to a USB memory stick) then you can buy a USB extension cable and place the fob closer.
Perhaps placing it next to the monitor would work best. If the receiver has a tendency to fall behind your desk, a small, clear piece of scotch tape will hold it down, and will be one hundred percent removable if you decide to move it later.
If your wireless keyboard or mouse have a desktop receiver, try moving it a little closer.
You may also need to press the "connect" buttons on the receiver and also underneath the keyboard and mouse.
If they have an on/off switch you should turn them on and off.
Hopefully this article will help you to fix your Microsoft wireless keyboard and mouse slow, **** or lockup problems.
If not, check with the technical support and Frequently Asked Questions sections of your manufacturer's support website.
hope this helps
Sep 04, 2012 | Lenovo IdeaCentre Computers & Internet
I want to know how I can change the mouse from left to right
Control panel and mouse. Look for Buttons and you can change the settings there. On Windows 7 just press windows key and type mouse....
You can also tweak other things, like how fast or jerky the mouse is, and how fast a double click needs to be for YOU. Also the scroll wheel can be altered for more or less scroll per rotation...
Nov 04, 2010 | HP Wireless Optical Mouse
Mouse needs to be reset. response time while using mouse is very jerky.
Make sure that your mouse is situated on non-conductor surfaces such as wood and/or plastic. The same principle applies is your sensor is connected via a cable and is movable.
Jul 15, 2010 | Targus Wireless Optical Notebook Mouse...
When I move my mouse over favorites, it is slow
After a great deal of searching and toggling many different options, I found a solution!
I am using Windows XP.
The option may be in a different place if you have some other version of Windows.
In Control Panel, Folder Options, View tab, scroll to the bottom and uncheck “Show pop-up description for folders and desktop items”.
I am not certain, but it also seems to have improved the general performance in Windows Explorer as well.
Oct 26, 2009 | Microsoft Internet Explorer 8
Jerky pointer and freezes
Possible solution for that, open the mouse and CLEAN the mouse.
May 06, 2009 | Mouse Systems PC Trackball II
When turning tue wheel on the mouse, the screen continues moving
Adjust your mouse wheel settings, to scroll less lines at a time. That should take care of it.
I hope that helps,
Eric
Nov 27, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Jerky mouse
Try using a different Mouse Pad or surface. This is a cause of jerky and erratic mouse movement.
Hope this is of some help. Bud
Oct 07, 2008 | Logitech Cordless Mouse
Wireless mouse
sometimes wireless mouse is a bit slow in responding.
use a mouse pad sometimes it helps.
Mar 26, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
David Payne
David Payne
