CHECK ON LINK BELOW YOU MIGHT HAVE TO COPY AND PASTE IT INTO WEB BROWSER
https://pdfweek.com/downloads/rascal%20taxi%204%20mobility%20scooter%20manual%20pdf
hi Hazel, this can be one of two things ,,,, 1. the controller has gone faulty
2. it's a loose connection to the controller...normally the long block, however if anyone decides to look at it for you please make sure the battery pack has been remove, I don't recommend this however that's your decision,...
hi, I have a thottle control that would work this , can you twist your wrist okay ?, go to ebay and look for electric scooters, normally three wires now goto the control panel where the charge indicator etc is and remove the cover then look for the three wires that come form the thottle part and replace with the twist grip wires , you may need to experiment to get it right but it can be done.
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
