Question about Minolta Office Equipment & Supplies
I have a minolta Dimage scan dual II. This had worked correctly until recently when it gave up. There is power coming into it, but this is only seen in terms of an internal light. It is not recognised by the software (even after re-installing). There is no indication of power from the scanner motor either.
  • Minolta Master
  • 19,396 Answers
Check if the cable is working, if cable and software are fine, the printer is faulty.
Posted on Jul 07, 2008
  • Ginko
    Ginko Jul 07, 2008
    Try also installing the Minolta on a different computer, sometime older corrupted drivers can leave behind files that prevent the printers from working.
    If you do not have another computer available try at least testing the printer on a different port.
    If the printer is defective, and it starts up but is not communicating with the computer it can be a fault in printer port or on printer electronics (pcb).
Konica Minolta Dimage scan dual film scanner will not connect to windows 7
It's possible there are no drivers running under W 7 for this remarkable unit and it's a shame .
If you have the W XP install disc , you could install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise ... trashbin . Yes , life is hard .
Regards .
Dec 26, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Does Kainanderson's solution work with Win7 64bit
Of course it does. I'm using both a Minolta Dimage IV and Minolta Dimage Elite 5400 Mk 1 (firewire and usb). Here's my latest driver:
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
May 13, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Need drivers for Minolta Dimage Scan Dual III to work with Windows 7 64-bits
I used this solution from KainAnderson
1) Install the Konica Minolta XP software in Win 7.
2) Plug in your DImage Scanner into a USB port and turn it on with the door closed. It may detect and install the original Konica Minolta Driver.
3) Create an empty folder on you harddrive (for instance go to my computer, double click on the c: drive, then right click and create a new folder named newminolta).
4) Open windows notepad and copy the following into it:
; scanners.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Class=Image
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
[Models]
; USB scanners
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
5. Now save you new notepad file in the directory you created as newminolta.inf NOT as newminolta.inf.txt or newminolta.txt (i.e. c:\newminolta\newminolta.inf)
6. Go to control panel (View Devices and Printers).
7. Right click on Minolta Scan Dual III and click on properties.8. Select Hardware tab, then select Properties
9. Select Driver tab, then select update driver
10. Select Browse my computer for driver software.
11. Browse to c:\newminolta\newminolta.inf (or wherever you stored file) and click Next
12. Click Next. After running driver file Win 7 should now say it updated driver.
13. Run Dimage software with door closed. Wait for it to initialize and green light stops blinking.
14 Open door and insert film holder and start scanning.
Hopefully I've copied and amended the solution correctly
Feb 10, 2010 | Minolta Dimage Scan Dual III Film Scanner
I have a Minolta Dimage Scan Dual II which has a power-on-reset problem. It only starts up properly when it has been switched off for a couple of days. Does anyone have a circuit diagram so that I can...
I probably have ran into this issue as well if I leave the scanner turned on, my Diamge Scan Dual II gives me an Error= 5 on Win2k or Error=1 on XP
Last night I opened the scanner up found a loose ribbon cable and managed to the scanner working however it was left on over night and Puked out with error codes again
Jun 07, 2009 | Minolta Dimage Scan Dual II Film Scanner
Software upgrade?
It works fine on XP, I am using it with XP SP3 currently. You should download the current driver from Minolta. Install the software before hooking up the scanner. I prefer to remove any existing drivers and re-boot before installing new drivers.
Apr 26, 2008 | Minolta Dimage Scan Dual II Film Scanner
Minolta DiMage Scan Dual IV
1) Install all of the usual Minolta software in Vista.
2) Create a new folder somewhere
3) Create a new txt file named minolta.inf and paste this into it:
[Version]
Class=Image
Provider=%Provider%
[Manufacturer]
[Models]
; USB scanners
[Models.ntamd64]
; USB scanners
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. All the normal Minolta programs now work just fine. Enjoy!
Jan 27, 2008 | Konica Minolta Dimage Scan Dual IV Film...
32 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
