Question about Frigidaire ATF6000ES Front Load Washer
Need new washer to stack on my dryer!
My washing machine is a Frigidaire Gallery GLTF1670ASO, and it has died. I need a machine exactly the same size so my Frigidaire dryer, which still works, can stack on top of it. Is this possible? Will I need a new stacking kit? What make and model would you recommend? THANK YOU
  • pirate3 Jul 25, 2008
    Our 7 year old frigidaire FWT647GHSO broke a shock and now needs new tubs and bearings (we had black grease marks like a crazed felt pen and octopus suckers all over the laundry). We now have a working dryer that will only stack over ONE model of frigidaire washer - the FTF530, which sucks according to reviews. We want something built better - with metal tubs and so forth so that we can get more than 7 years of use out of our $600+ purchase.
    Can we jerryrig a stacking assembly so that we can buy a better washer and still use our dryer? The dryer works great...
  • dmervold Oct 07, 2008
    We also have a 7 year old frigidaire FWT647GHSO washer the the shocks went and the tub fell to the floor. We also need to find a washer that will stack with our dryer. HELP!
  • 876 Answers
Measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Posted on Aug 13, 2008
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
A loud bang .....like a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Feb 14, 2009 | Frigidaire Washing Machines
Stacking a frigidaire washer and dryer
This stacking part is all you need. It is a white plastic bracket that attaches from the rear of the two appliances. And it should have come with instruction too.
Dec 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
Jul 28, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire GLEH1642DS1
Check the door switch on the dryer to make sure the leads are all on.Check your thermal fuse .Its likely that its one or the other.
May 20, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Check the thermal fuse, a small disc with two wires on it located at the top of the heater housing at the rear of the machine. If it's blown definitely check your vent system for restrictions
Dec 26, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire Gallery Front-loading Dryer Stops Tumbling
I have a stacking Frigidaire washer/dryer. The dryer will not start at all.
Thanks for any info you can offer.
Dec 23, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Removing the agitator
Pull the top of the agitator off...there is a nut inside of it (ratchet and socket usually 5/8 and a long extension) pull agitator out.
Nov 18, 2007 | Frigidaire GLEH1642DS Front Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
540 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
