I my remote control had Hawaiian punch spilled on it and now it will not work. The buttons are not stuck but it will only turn the television on and off. What can be done? I cannot even work the buttons on the television and it is only 2 years old.
It would be best, to simply buy a new remote control. I own a One-for-All universal remote control (model URC-4220), and it works with all brands of TVs, including Insignia TVs. I bought it at Walmart, and it cost less than $10.
I had same issue and it turned out that the actual channel down button on the side of the TV itself was stuck. Popped it out with a knife (IKR) and that fixed the issue. Works fine now
Find magic button or setup button. Turn on device. Hold down button you would like to program it may blink twice. Punch in 911. Toggle between power and device until device turns off. Hit magic or setup button. Hope this helps
in most cases when some remote buttons no longer work it is due to some fluid being spilled on to it or it has simply blown a curcuit that completes the current if its a fluid spill the remote needs to be pulled appart and both the rubber controls pad washed as well as the curcuit bord replace the baterys put the unit back together and it should work fine
Must have a bad remote control then . Did something spill onto the remote near the power on button? Short of getting a new remote you could try poping thr remote control apart and cleaning it out with a mild detergent. Larry's Electronics
press and hold tv button till light stays on enter 4 digit code if code is entered properly light should go off then turn tv off with remote if it does try to turn on if it does your in good shape if it doesn't turn on try diff code 0062 0204 0207 0183 0226 0288
Does this model have the control buttons on top of the set? If so most of the time re-routing the cables inside the TV that go to that board solve the problem as high voltage static from the CRT cause issues with the micro. Or you might have one or more switches stuck or something spilled on them.
