Question about Insignia IS-LCDTV32 32 in. Television
I beleive that the red color is not working most of screen is brown
    Guru:
  • 2,178 Answers
I don't think it's a red color issue - the LCD or the color processor board is bad. If you know how, re-seat the circuit boards inside the unit and check the ribbon cable that connects to the LCD display.
Posted on Dec 29, 2010
No red color on screen
there are three basic color controlled by electronic circuit, in picture tube gun,one of them not working properly.needs detail analysis
Dec 04, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Trying to wire in a new stereo into nissan largo, found power but cant find speakers. is there an in line amp that i need to power up to make speakers work?
This might help.
Wire colors in your car might be different than colors described here. Use the given colors for reference purposes only. Always test wires to make sure they are correct.
NISSAN P o w e r Memory (+12v Constant) Red Ignition (+12v Switched) (varies) Brown or Green Ground (-) Black (varies - most don't have one) Illumination Red/White Dimmer Red/Black Power Antenna Green S p e a k e r s Right Front (+) Brown Right Front (-) Brown/White Left Front (+) Black Left Front (-) Black/White Right Rear (+) Blue Right Rear (-) Pink Left Rear (+) Red Left Rear (-) Green
Mar 28, 2009 | Car Audio & Video
Trailer light problem
Check it with a test light. White-ground, Yellow-left turn, Green-right turn, Brown-tailights. Check it on the truck first. There are seperate fuses for just the trailer wiring in the fuse box under the hood. The Blue and Red wires are for Trailer brakes, don't worry about those.
Mar 14, 2009 | 2005 Chevrolet Silverado 1500 2WD
Mitsubishi WS-55511 55 in. Rear Projection Television No red colo
do you see any red at all when you co to the convergence screen? if not, then the red CRT has died and needs to be replaced.
Jan 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
3 year old Mitsubish 52" DLP mdl.WD-52627 TV displays all "Red" colors as Brown-Grey in color. Going to the color level menu and maxing out the Red color bar does no good. Also intensifying...
Found out I have extended warranty and I am awaiting service company to respond in order to conduct service to find the problem.
Thank You
Jun 30, 2008 | Televison & Video
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Dark (brown-yellow) area on the screen
Dalnel97,
Did you ever find a solution to your yellowish brown blob? I have the same problem with mine here at work.
Jun 12, 2007 | Panasonic PT L720U Multimedia Projector
Insignia IS-LCDTV32 32 in. Television Logo
95 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
