Hi, I have a philips GoGear 4GB model No. SA324502 and I'm charging it up on my pc. it shows it's charging but when it's fully charged and I turn it on it starts of normal then comes up no charge in battery!! is there a battery inside that can be renewed? Jeff Foreman.
  • jeffforeman5 Dec 29, 2010
    Hello' this does seem to have reolved the problem.
    thank you for your prompt response.
    regards
    Jeff Foreman
  • 3,530 Answers
Welcome to Fixya
Try to reset the gadet first. Get a small object like a paper clip and use the edge to stick into the small reset button on the side next to the usb connection.
Thank you for using Fixya!
Posted on Dec 29, 2010
How do I fix my philips gogear 4gb
Lithium ion batteries, if allowed to be drained all the way too many times will stop taking a charge.
Replace the player.
Apr 03, 2014 | Philips GoGear Vibe 4GB MP3 Player...
When I try to turn on the MP3 (Philips GoGear Mix) I see a symbol of a battery and then it shuts down. When I plug the MP3 to the computer it shows it is fully charged. What shell I do? Thanks
I have had a GoGear for a while and those things have horrible firmware and are very fragile. I have experienced the same issue myself, so I suggest leaving it plugged in for several hours no matter what the screen says to try and let it charge. It should charge up. If not, try charging via a usb wall charger, which should allow usage of the player while it charges.
Jun 01, 2011 | Philips GOGEAR SA6045 MP3 Player
My philips mp3 turns on to the philips screen, but then turns right back off. nothing seems to work such as: restart button, usb, etc.
Hi Are you sure the gogear is fully charged, your problem is symptomatic of a failing or uncharged internal battery.
Sep 30, 2010 | Philips GoGear HDD6330 MP3 Player
Batterylife,GoGear Vibe 4GB how long between each charge, getting 5 to 6 hours.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
Aug 05, 2010 | Philips GOGEAR SA6045 MP3 Player
I bought a Gogear 2gb philips SA018 mp3 player i dont know how to start it and download anything theres no instructions and its not showing anything. how do i charge it?
I have problems with the Philips SA018 4gb MP3 player. While it is connected to the computer the it shows green once it is disconnected it goes red and nothing works.The battery should be fully charged as it shows green,but as I have said once it is disconnect it turns red and that's it...there is no joy.I wonder is there a problem with the battery...? Has anyone else had this kind of issue?
May 21, 2010 | Philips GoGear SA178 MP3 Player
Philips GoGear 4GB Mp3 wont charge anymore. I need to know how to fix it.
Make sure the lock switch wasn't accidentally engaged. If it is unlocked, and it's still not charging, run a Repair in the Philips Device Manager. If it still will not charge, then the issue is hardware-related - contact Philips and find out if the player is still in warranty.
-Tha Mp3 Doctor
Feb 12, 2009 | Philips GOGEAR SA6045 MP3 Player
Please HELP!
If solution 1# does not not work try this then attempt solution 1#, I had the exact same problem solution 1# did not work until I did this first. Do a quick format on the player by right clicking the drive(drive J: for example) in my computer, and choose format, then check the box that says quick format. After this your player should be fully functional, but nonetheless follow the instructions to repair it completely as stated in solution 1#
Feb 01, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear audio video player 4GB...cannot update
Make sure the lock is not engaged.
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Sep 13, 2008 | Philips GoGear Flash MP3 Player
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
291 people viewed this question
 Grubhead
Grubhead
