Question about GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
I have a GE Adora M# DSF25KGTABG. Set temps on the freezer door to 0 and 37. runs great for a few days then drops down to -9. I have replaced all thermistors and the mother board. What would be the next step?
I have the GE Adora DSS25KSTB ss and the temps will not hold to cool temp.
We set it at 0-25 and the refg to 35 and sometimes it will cool to that temp and then sometimes it is a lot warmer.
Posted on Jan 15, 2011
  • gjgallman
    gjgallman Mar 15, 2013
    We are having the same problem as we have had this problem twice in the past and the frig is only five years old. I am spreading the word NOT to purchase one of these models. Nothing but trouble. The service man can't seem to get it right either.
My GE Adora freezer section constantly gets down to -5 to -9 degrees, when the setting is 0.
I would advise replaceing # 4 AND # 5 thermistor . The # 4 , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils ( remove the inside rear freezer panel ) , with 2 white wires going to it . Part number WR55X10025 for both . The # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Jun 13, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
I have a GSS25WST side by side refrigerator/freezer. I have the freezer temp set to 0 and the refrigerator temp set to 37 but according to the "current temperature" reading on the front panel it says the...
The door light switch controls the evaporator fan which circulates the air through out the unit properly. Replace the bad switch and things should go back to normal. WR23x10161 at about 10.00. Good luck. Rick
Mar 10, 2010 | GE GSS25WSTSS 25.4 Cu. Ft. Side-by-Side...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Water overflowing into ice bin and down back wall of freezer. Replaced icemaker and water inlet valve . Model is GE Adora DSF25KGTABG. Water pressure is 55 lbs.
Sounds like the condensate drain line in the rear of your freezer is blocked. Every time the freezer goes into defrost this most likely will happen until we clear the blockage. I will help if you like. Now you mentioned the water pressure. that too is very high and I would consider having that looked at. But if you turn the water off it stops?
Let me know, Sea Breeze
Oct 16, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Freezer does not keep ice cream completely frozen. I vaccumed out the dust from the coils in the back and raised the temp. setting from 6 to 9 maximum setting. anything else I should do?
there might be 2 possible solutions to this.
either you have your freezer temperature turned down or when you get low on freon your motor cannot cool the freezer part.
Jul 10, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
GE Refrig MODEL GTS22KPB defroster not running fridge warm/freezer cold
you need part WR55x10552 Main Control board it is embedded in the back wall of the unit with a cover plate about 6"X8" unplug and replace this board ctrls it all
May 28, 2008 | GE Refrigerators
GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
529 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
