Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My whirlpool washer stopped gyrating but I can her the motor running. What is the problem?
2 Suggested Answers
pride applia
  • 232 Answers
SOURCE: cycle stops motor hums whirlpool top load
bad points in timer or bad motor take the motor out and to a used washer shop and see if they will test it for you for a small fee if it tests ok get a timer
Posted on Dec 25, 2009
Whirlpool washer runs all the time drain fliter is clean
check pcb, drain pump releated traic check it could be faulty
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Washing Machine Motor Coupling Repair
How do you tell if your washer motor coupler has gone bad? Motor couplers are used on "Whirlpool" direct-drive washing machines. In some Whirlpool or Whirlpool-made washing machines, the motor coupler connects the drive motor to the transmission. It operates under extreme conditions and stress. Mostly during start-up and stopping of the motor. The main symptom of a bad motor coupler in the Whirlpool made washing machines is that there is no agitation or spinning action, along with the sound of the motor running. Since the motor is running, but there is no connection to the transmission, the machine will not agitate or spin the clothes out. The motor will simply run, but nothing else happens. In this case, the coupler is most likely cracked. To replace the coupler in the Whirlpool made washer, you must first unplug the washer, remove the top console by either removing the screws or using a putty knife to unsnap the top clips, rotate the console back, pull the washer front off by tilting back,and set the cabinet aside. Remove the clips holding the pump and motor on. Remove the bolts holding the motor on. Inspect the coupler and replace with a coupler if necessary. Re-assemble the motor and pump assembly. Re-assemble the washer in reverse order of disassembly. Plug in and test by running the washer through it's paces.Here is a video on repairing the motor coupler.
on Oct 18, 2011 | Whirlpool Washing Machines
Gyrator is stuck and will not move there is a
FAV6800A or FAV9800A correct?
You may have One-Way Roller Clutch rusted solid and the Motor drive belt is slipping burning rubber smell?
Please confrim the model number of your machine and we will go from there.
Dec 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Cycle stops motor hums whirlpool top load
Dec 25, 2009 | Whirlpool Washing Machines
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Whirlpool Calypso Washing Machine "Cl or Ca"
The control board is reading too high of an amp draw from the motor,Most likely a bad drive motor.
Sep 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Tub and Basket
Fairway, sounds like you have a worn drive block. You are going to have to remove the agitator and inspect the drive block. If it is the drive block you will get some good hammering when the spin cycle stops. I will attach some photos of a worn out drive block. If you want to attempt to handle this yourself, we can walk you through it. Catriver..post back.
Oct 23, 2006 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
