Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
I replaced the water valve in the back of my GE fridge, but I think I misconnected the lines! What is the correct connections?
  • 2 more comments
  • gerrywyso Dec 30, 2010
    the water connections, I've got the water supply on, but there are two lines going into the fridge (Ibelieve for the ice and the cold water) another going to the bottom of the fridge (?) and another which is connected to nothing in the fridge. I replaced the water valve, forgot to mark the lines and were they go.
    Neither one! what came out was 197D187G003, the replacement is WR57X10022. Four connections excluding the water input, I got the cold water on correctly, it has a bigger line than the rest. Opposite the water input from the wall is another connection with an orange connector, on the other valve is three connections, one for cold water (got that one) a white ice connection and a dark connector one the bottom.
    The valve P/N is WR57X10022, it has two seperate blue valves, one with the input from the water feed, and the other output has an orange connection on it. The other blue valve has an output for the cold water - got that one its bigger than the others, an ice output and a black/brown connector.
  • gerrywyso Jan 03, 2011
    It worked, thanks Rich! I should have marked everything before I tore into it.
    Top Expert:
  • GE Master
  • 9,472 Answers
What connections are you concerned about on the valve?
Posted on Dec 29, 2010
  • Richard Roth
    Richard Roth Dec 30, 2010
    Which valve did you get? There are a couple of different one for that unit. Take a look at the pictures below and let me know which one it is.
  • Richard Roth
    Here ya go! This diagram should do it for you.
    Please let me know how it goes.
    Rich
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Mar 03, 2014 | General Refrigerators
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
GE side by side fridge is dripping water from the fill tube and freezing. I unplugged ice maker and it still does it. I'm guessing it is the water valve or something electrical?
the water valve on the back of the fridge is bad.sediment most likely got in the valve and it isn't seating correctly and water is leaking by.change the valve.
Feb 27, 2011 | GE Kitchen Ranges
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
No filtered water
More than likely you need a new water valve in the rear. You can test this by going to the back of the fridge and taking off the rear panel then remove the water line going under the fridge to the bottom of the door. This works great if you can get help. Just have the other person pull on the hose going in the bottom of the freezer door to help dentify the right one. Once the correct line is removed from the valve, have your teamate push the water paddle in and see if any water comes out of the valve itself where the line was. GE water valves do go bad quite often.
Jan 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
On a ge fridge, side by side built in, how do you get to the water inlet valve for the icemaker? The model number is z1sb42dca
The water valve , is the piece on the back of the refrig , that the wall water line connects to . Remove the back panel , and 2 screws , hold the valve on .
Dec 20, 2009 | GE Refrigerators
Ge fridge, water and ice on the door ,, all of a sudden the waterstopped working on the door ,, but it still makes ice
There is a double water valve in the back of your frige that your water supply connects to at the bottom. You will need to replace this valve. It will have your water supply connect on one end and two lines connected to the other. You can test it to be sure by doing this. Disconnect the two lines that are on one side. Using a towel to catch the water, have someone push the leaver in the front of your frige that you push when you want water. If the valve is good water will come out at the pressure you normally have when you are filling a glass from the front. If it does not come out, you will need to replace the valve.
Aug 15, 2009 | GE Refrigerators
Water leaking from ice maker GE model# TFH22PRS
Hi
Please check to make sure the water tubes are attached properly and are fastened tightly.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 16, 2009 | GE Refrigerators
Water Dispensor drips
You probably need a new water valve in the back of the fridge the valve is not shutting off completely  replacing valve will correct this problem
Nov 13, 2008 | GE GSS25JEMWW Side by Side
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
