Question about Hotpoint TDC32 Electric Dryer
Require wiring diagram for TDC62 timer - Hotpoint TDC32 Electric Dryer
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
I have TORK 1104 , I need control 2- louds (same face) I understood L- hot 1 from breaker, 1- hot 2 from breaker, X- com to loud 1, 2- is com to loud 2. BUD WHERE MUST BE CONNECTED NEUTRAL???
Tork 1104 is 240Volt timer.
Same timer is repackaged and sold as GE 15307
See wiring diagram for single load 240Volt:
http://waterheatertimer.org/images/GE-15307-wiring-250.jpg
On the 1104, there is not a separate terminal for Neutral wire.
240Volt circuit does not require neutral wire to complete circuit, so 240Volt timer does not have terminal for neutral.
If you want to control two 240volt loads, then this is not the best timer.
I recommend GE 15207 from Home Depot or Heavy-duty Intermatic GM40 available on-line.
If you want to control two 120Volt loads using Tork 1104, then connect 240Volt lines to to terminals L and 1 as shown in diagram above.
Bring your neutral wire into the box, but do not connect neutral to any terminal.
Each 120Volt load has black and white wires. The whites are for neutral so tie them into the neutral wire using wire nut. Connect black wires to terminals X and 2. If you want both 120Volt loads on same phase, then connect both black wires to terminal X.
Resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Sep 25, 2011 | TORK Variable Cycling Timer 8601
When I hook up a new timer it starts to make a clicking noise and the lights do not go on. I have put in 2 different batteries and the timer still makes a clicking noise. The light timer is for a 3-way...
Your wiring is probably wrong.
Wiring is tricky for 3-way timers.
First of all, both 3-way switches cannot be replaced with timers ... just one of the two switches is replaced.
You don't say which timer you have.
Since I know the wiring and the timers, let me jump in, and you can add a comment, and then we can work further.
A) You have battery-operated ST01C or EJ500.
Here is wiring diagram for Intermatic battery-operated timers:
http://waterheatertimer.org/ST01C-program.html#3way
Note that at all times, the blue wire has to go to load, and that the blue wire connects to dark-colored screw on 3-way switch.
Note that the remaining 3-way switch is not wired the same as before. The red and blue wires have to be wired exactly as shown, and the wiring might require additional wire running between the switches.
Now add a comment with your wire colors and description where you are in the wiring.
B) You have Aube timer with rechargeable battery.
T0132 manual shows wiring diagrams
http://waterheatertimer.org/Aube-T1032-timer.pdf
Below is image of typical Aube wiring.
The manual shows one other diagram depending on which switch is being replaced.
The important this is note that the wiring on the remaining 3-way switch requires a jumper wire from the dark-colored screw to the brass screw on other side of switch. But it has to be the same brass screw that goes back to Aube timer #1 wire.
Usually this little difference solves the 3-way switching problem, but add a comment any time.
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Flickering bulbs
You posted under EJ500 Intermatic battery-operated timer.
If you have different timer, add a comment.
I have tested EJ500 timer.
A) If this is new single-pole installation and lights click on-off when timer turned on, then you connected red wire where blue wire should be connected.
Manual says for single pole switch:
Timer-black-wire to Hot; Timer-blue-wire to Load (lights)
Here's how to wire timer correctly:
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-blue-wire. Choose either one for now.
3) Put wire nut on red wire.
4) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-blue and timer-black wires.
B) If you are replacing 3-way switch, view wiring diagrams shown on link below, and then add a comment saying exact color of wires. To wire this timer for 3-way can require additional wire between switches. This is because EJ500 blue wire must always go to Load (light, fan, motor)
http://waterheatertimer.org/ST01C-program.html#EJ500-wire
C) If this is older timer that stopped working, check your bulbs. Then check timer battery. Manual says if timer stops working and bulbs are good, and battery good, then reset timer and reprogram. How to reset timer. Press reset button while holding down Next/ON-OFF button.
EJ500 manual has long list of programming instructions: Add a comment if you forgot parts of programming.
EJ500 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej500c%20-%20english.ashx
Nov 28, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
How do i wire a Paragon 4001-00 timer?
Link below has wiring diagrams for 4001-00 timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Manual with wiring diagram:
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
4001-00 is wiring diagram #1
There are 3 terminals 1 2 3
Black Hot wire from circuit breaker goes to terminal 1
Black wire to Load (light, fan, motor) goes to terminal 2
Whites wires connect to terminal 3
Aug 13, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Help with Woods 59018/59028 7 day digital timer
The usual connection for this type timer is the house black power to the timer black, the house white power to the timer white and the , the light black wire to the red timer wire.
If you only have two wires, one black and one white, at the switch location, then you cannot use this style timer , as it needs a neutral. You should return this timer and get one that does not require a neutral connection.
Please Vote !!
Jun 01, 2010 | Woods 59028 Programmable Timer Switch...
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
How to change a timmer on a whirlpool washer
UnPlug. Most timer access thru Top Back Panel. Most all timers Have Color coded wires and Unplug with Spadelugs. Make a Diagram Sketch. I Always Tape # on them or some Timer assemblies Have a Master Coded Plug. Just Unplug and Plug new one in. Appliance Places are Helpful, Useful. Will Sell You Parts & Give You Tips. Have Make, Model. Call or stop by. You're Saving the Labor. Make sure the timer is Bad. Testing and Troubleshooting with a Little Knowledge will get Your Job Done. A Few will Require Tieing in wires with **** Splices.
Aug 16, 2008 | Whirlpool Washing Machines
Hotpoint Utima Logic Sensing Condenser TDC62
lewensc...this sounds like a classic timer issue. Before replacing it, first turn off your mains breakers and then back on. Check all wiring from the breaker panel to the unit. If okay, then have a quick look at the items in the dryer and test them using a multi tester. If nothing is amiss, replace the timer.
Dec 17, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
103 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
