Question about Dometic Rooftop RV Air Conditioner
Compressor on AC does not go off.
My compressor never goes off, even when temp is on lowest setting, and after leaving it on for quite a while there was not much force to the air coming out anymore. Is it freezing up? Why doesn't the compressor ever go off like my other AC unit?
    Novelist:
    Champion:
  • 230 Answers
If it is sized correctly I would assume that the problem is a stuck contactor relay. They some times weld themselves closed when they get old.
Posted on Jul 07, 2008
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
I have a neo plasma LG air conditioner, i am having problems switching on to cooling, sometimes it works, other times it is just circulating the air, making the room hot, it is 4 yrs old.
Possible problem with the thermostat which might be sensing the wrong temperature and so is not switching ON the compressor. So if the AC works once it is ON then the gas and compressor seems good. So you must check the thermostat and control board. Set the AC to a lowest temp and try.
Jan 24, 2011 | LG Heating & Cooling
My Whirlpool window a/c is not cooling as well as it did last sum
I know it has been at least a year since your post. I am answering the post to terminate FixYa site activity on the post.
Remove the front cover. Check the routing of the temp sensor wire. It should go from the bottom of the control panel to the plastic clip in the evaporator coils. If it is touching the eavporator coils it will sense the refrigerant temp and cycle off early. If the unit is freezing up there is a restriction in the coolant lines and usually will require the coolant system be purged of foreign internal debris.
Thanks for choosing FixYa.
Kelly
Jun 25, 2009 | Whirlpool ACC108PS Air Conditioner
Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Dec 24, 2006 | Sanyo SR-3620 Compact Refrigerator
Dometic Rooftop RV Air Conditioner Logo
83 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
