Question about Dell Inspiron M5030 Laptop
Dell Inspiron M5030 frequently locks up when using word, internet explorer, onenote, etc. Task manager takes a long time to start, will not end a program that is not responding. Have to do a hardware shut off; will not reboot, but hangs with a black screen after login. Can reboot in safe mode or safe mode w/networking at present. I have installed MS Office Enterprise 2010; and Spyware Doctor w/Antivirus. Also have iTunes. Service tag # B3DM7N1 Express service code: 24148875565
    Brigadier General:
  • 8,909 Answers
I would make sure it is up to date asfar as Windows Updates are concerned, check the internal RAM, (Press F5 whilst booting and run the utility) and download the latest BIOS and drivers from Dell.com
Hope that helps.
Posted on Dec 29, 2010
What does it mean when i powered on my Dell Inspiron M5030 it beeped 5 times and asked for the system password?
Can you check in your CMOS to see if you have the system password enabled? If so you may need to disable it.
Sep 16, 2014 | Dell Inspiron M5030 Laptop
My dell inspiron m5030 laptop goes to my background screen with nothing to choose.wat happened?
They are hiding behind background screen and discussing between services in background for conspiracy against you. Not really as it was, windows is processing a start up item, if it really doesn't load anything perhaps your explorer is stop working or taking a longer time to load, try pressing Ctrl+alt+del, open task manager, click on "Processes" tab and try look for "explorer.exe", if it doesn't show there you go to "File" menu and click "new task (run)" and type explorer, if you can find explorer.exe in task manager, right click to it and select "end task" then after it gone repeat step before.
Aug 07, 2014 | Computers & Internet
What is debugging?
First I will suggest you to update your display drivers to avoid black screen
Just go the site of your Laptop manufacture. Once there enter the model number or service tag no of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
After that Open task manager and close any unnecessary processes running in background
Click start>Run.. Type msconfig>enter>Start Up. Uncheck the boxes for the programs that you think you may not use often
Uninstall unnecessary programs (Games, crapware, toolbars, etc.)
Let me know if it helps you.
Use system utility tool like RegInOut to and fix registry and windows errors which causing these issues
Jul 08, 2013 | Dell Inspiron M5030 Laptop
How do I set the space tabs on Dell Inspiron M5030
The only place I am aware of is in MS Word.
MS Office 2010 Word - Right click anywhere on document and using Paragraph. Custom Indents and Spacing are set there.
Oct 12, 2012 | Dell Inspiron M5030 2800B3D 156Inch Laptop
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
Hi, my gf's dell inspiron 1525 will not open any programs, not even the the start bar, how can i fix this, and also, should she be running the sims game on it?
press ctrl + shift + esc together task manager will appear , click on the applications tab and click new task,type explorer and press enter , your task bar etc should appear. IF it does i would do a full scan of your pc with an anti virus program and a spyware program
Feb 23, 2011 | Dell Inspiron 1525 Notebook
I have somehow messup my Dell XPS M140. It starts normally, goes to the desktop, everything but the background disappears and it just stays that way. Anyone have any suggestions? I am just starting out...
Windows explorer is the process that runs the start menu, desktop icons, and many other things. It is likely that this process is being ended for some reason, possibly due to a virus. To restart this process, press ctrl+alt+delete on the keyboard, go into task manager, click new task, type explorer.exe, and click ok. I would recommend doing a full system virus scan after this to eliminate the problem in the future. Good luck!
Jan 18, 2010 | Dell Inspiron XPS M140 Notebook
I m unable to shut down my inspiron..............every time i does it , it gets stuck......& i have to shut it down by power button......plz help me out
You have a process that is not shutting down,Try this,Hit control,Alt,Delete and open the task manager,On the process tab,you can see what is running,End task on everything BUT Explorer.exe,logon.exe,and The svchost.exe(you will have a bunch of these)After you have end task on everything else,Try and shut down.
Jan 06, 2009 | Dell Inspiron 710m Notebook
E-mail with attachments freezing
Goto windows update, and make sure you have the latest version of Microsoft .net framework.. (also any other service packs for ie7 that you don't have, along with security updates)
Most of those sites use the .net platform, and that may cause issues if it is not up to date.
Other then that, you might try to re-install IE7, or, revert back to Ie6
Mar 28, 2008 | Dell Dimension 4600 PC Desktop
Dell Inspiron M5030 Laptop Logo
327 people viewed this question
Alun Cox
