Question about Canon imageRUNNER 400S Copier
E5F5 error what does this mean? - Canon imageRUNNER 400S Copier
  • Canon Expert
  • 122 Answers
Sticher home position not detected check sticher motor or sticher home position switch
Posted on Jan 01, 2011
I have a R 93 ami jukebox and keep haveing error codes 1and4 what do they mean
Error 4 means the memory backup battery inside the Central Control Computer is dead or very low. Error 1 means factory defaults are being loaded due to a dead battery.
Jun 15, 2014 | Wurlitzer Jukebox CD Player
Tip
Error code CANON iR2270 / iR2870 / iR3570 / iR4570 ...
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E713 communication error for finisher
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high.
0001 While startup control is under way, the reading of
the main thermistor is less than 30 deg C
continuously for 200 msec or more 1 sec after the
start of power supply.
the main thermistor is less than 70 deg C
continuously for 200 msec or more 2 sec after the
the main thermistor is less than 120 deg C
continuously for 200 msec 6 sec after the start of
power supply.
The startup control does not end 30 sec after the
Reset the condition in service mode:
COPIER>FUNCTION>CLEAR>ERR. Replace the
main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high.
0000 The reading of the main thermistor is 250 deg C
or more continuously for 200 msec.
0001 The hardware circuit detects overheating of the
main or sub thermistor for 200 msec.
Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the
E002 The rise in temperature of the fixing assembly is faulty.
0000 While startup control is under way, the reading of
the main thermistor is less than 115 deg C
continuously for 400 msec 1.3 sec after it has
indicated 100 deg C.
the main thermistor is less than 150 deg C
indicated 140 deg C.
E003 The fixing temperature is too low after a standby state.
0000 While regular temperature control is under way,
the reading of the main thermistor is less than 140
deg C continuously for 400 msec or more.
E007 The rotation of the fixing film is faulty.
0000 While the fixing motor is rotating, the marker
signal is not detected for 6 sec with the reading of
the main thermistor indicating 100 deg C or more.
REPLACE FIXING FILM ASSY(HEATER)
To enter service mode:
* 2 8 *
on Aug 03, 2010 | Office Equipment & Supplies
What does this error mean dryer has error f-01?
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
May 04, 2014 | Kenmore Dryers
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
Need a error list for a Canon IR 600 imagerunner
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
My photocopy of canon ir3100f the give massage code error on screen i want solution
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E602 Hard disk error
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E732 Reader communication error
E733 Printer communication error
E740 Abnormality of the Ethernet board
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
Jun 26, 2010 | Canon iRC3100 Printer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Oven won't heat after E5F5 error messages
Unfortunatley on that model the keypad is a bit spendy. It's around $100.00 Here is the link to what part it is. You maybe can search around and get it a little cheaper. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=KEBC147KBL04&productCategoryId=0125300&brandId=0593&modelName=BUILT-IN-OVEN---ELECTRIC&diagramPageId=00002&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0410072&backToLink=Return%20to%20Sub%20Components%20list
Apr 19, 2009 | Kitchen Ranges
Canon imageRUNNER 400S Copier Logo
22 people viewed this question
old marine
old marine
