Question about HP Officejet 4355 All-In-One InkJet Printer
How to change an printer from fax back to print ?
My MX700 printer tries to send faxes instead of printing page(s).
hi
change your default printer your mx700
1 - start menu
2 - printer and faxes
3 - right click on your printer
not on your fax icon
Jun 09, 2010 | Canon MX700 Office All-In-One InkJet...
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
Dec 11, 2009 | Brother MFC-465CN InkJet Printer
Can fax out, incoming faxes going to memory
Now I am very suspicious they hooked you to a DIGITAL phone line.
Make them change you back to ANALOG.
ALL fax machines are ANALOG devices.
Aug 20, 2009 | Samsung SCX-4216F All-In-One Laser Printer
HP Officejet 4500 keeps defaulting to fax mode
check the setting like menu look in there somewhere
Jun 05, 2009 | Office Equipment & Supplies
Low ink message with incoming fax, no fax but printing works fine
Unplug the machine for 3 minutes and plug it back in. sometimes this will reset everything. good luck
Feb 04, 2009 | Canon PIXMA MX310 All-In-One Printer
How to print 2 sides on hp laser jet 9050
start
settings
printers&faxs
open printer properties
tick mark print on both sides
Nov 28, 2008 | HP Computers & Internet
Cartridge problem of the fax.
Are you saying the fax appears to print but is blank or it does print but is not in a fax form but freestyle with no background format. Changing a cartridge will often upset the apple cart. see if the printheads could do with a clean. Make sure you reset ink level sif your unit does not automatically do this. Try a reset too by turning unit off, unplugging all cables, replugging all and turning back on. Post back if no good.
cheers,
lilacgerry
Nov 14, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP Officejet 4355 All-In-One InkJet Printer Logo
273 people viewed this question
Seeker5211
Seeker5211
