Question about Maytag MSD2656G Side by Side Refrigerator
My Maytag MSD2656KES Side by Side Refrigerator is leaking water on the left corner on the refrigerator side (if facing from the back.) I see a hole where it looks like a drip pan is filing up with water, but can't see where the water is coming from. Please advise. Thanks
SOURCE: Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
Posted on Sep 15, 2008
docjohn174
  • 943 Answers
SOURCE: How do I clean my drain pan on my side by side refrigerator it smells
Hi. Thanks For The Question. Pull Fridge Away From THe Wall. Remove Back Panel Clean All Coils. Remove Drip Pan. Clean. Thanks The Appliance Doc
Posted on Oct 03, 2008
  • 1122 Answers
SOURCE: refrigerator not getting cold enough
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
Posted on Dec 06, 2008
lojacksdad
  • 121 Answers
SOURCE: where is drain hole on maytag MZD2766GE side by
in the freezer at the bottom can be seen by removing back panel hot water will open it up if not blow through with small hose
Posted on Apr 17, 2009
alex_salve
  • 78 Answers
SOURCE: maytag side by side refrigerator ice forms at the bottom of freez
DEFROST THE FRIDGE BY SWITCHING IT OFF FOR 2 DAYS
Posted on May 25, 2009
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Water leaking from the bottom of frig
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
May 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Water leaks out the left front. Water seems to pool and freeze in the bottom of the freezer. The leak is not alot but it never stops. Have checked for level have disconected the water and ice maker. Still...
You have a plugged up defrost drain. There should be a drain hole way in back of the freezer, at the bottom. (it should be behind the panel at the back of the freezer compartment) Use a turkey baster with warm water to flush it out until water runs out the hole into the defrost drain pan under the refrigerator.
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
MAYTAG Model MSD2656KES: The refrigerator works
Sounds like the control module is u/s or the motor is u/s. Try switching off and on at the mains. If this does not cure it then you can try to unplug and plug back the ice motor, if you have access to it, if not call service engineer.
Aug 28, 2009 | Maytag Refrigerators
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
My fridge is freezing my food on my maytag msd2656kes. i have turned temps down and still freezing my fresh food. any help would be appreciated
make sure you turned them the right way the dials are very easy to misread if not your thermostat is stuck closed
Aug 11, 2009 | Maytag 25.6 Cu. Ft. Side-by-Side...
Leaks water periodically onto floor bottom left corner freezer side
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com.
Jun 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator leak
May 20, 2008 | Maytag MZD2766GES Side by Side...
Maytag MSD2656G Side by Side Refrigerator Logo
59 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
